Engine Ticking Noise... please help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryn01599, Mar 4, 2018.
  1. Ryn01599
    Ryn01599 Hybrid Owner for Life
    rohnert park
    2006 Toyota Prius with nearly 200,000 miles on it has a ticking noise from the engine when turned on. When the engine is on the ticking is heard and appears quieter at higher speeds but noticeable at all times. It’s rythmic and sounds louder to the left of the engine.
    Mechanic said it might be the timing chain tensioner or sham bucket but was unsure and quoted $2,000 to take apart the engine and fix. Thoughts?
    Abdu_mka likes this.
  2. Patrick Wong
    18,210
    6,513
    Wait until the engine fails, then have a used engine installed.
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    I sold a blue 2006 that sounded just like this. It ran fine but the engine is probably worn and will need replacement soon
  4. Ryn01599
    rohnert park
    It still runs fine but you do you think it would be a new engine vs a repair or two to fix it?
  5. JC91006
    16,827
    8,600
    Alternatively you can sell the 12 year old car.
    It would be very costly in labor to try and fix the problem, even then you'll still have a 200k miles motor that may or may not be fixed. Another used motor would be nearly as expensive ($1000+) but the problem definitely won't be there after you replace the engine
    edthefox5 likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    It may be piston wrist pin is failing. It’s not the timing chain. Answer me this ......how many times has the oil run so low a red triangle came on or you see that once in awhile going around corners.
    With engine running get under front of car to listen to bottom of engine. Or take the oil fill cap off and see if it’s real loud coming out of that hole. Top noise or bottom noise.
    But like jc said no matter what it’s a lot of $$$ to tear into an engine unless you do it yourself.
    Dealer at $140 an hour is out of the question. Have no idea where rohnert park is.
  7. Stevewoods
    Stevewoods Senior Member
    663
    1,200
    Seattle, WA
    O.K., I am old school, but couldn't it just need a valve adjustment, or possibly an exhaust manifold leak (that caused a ticking in my 1962 Falcon in about 1981..).
    I would not just jump to new engine....
    #7 Stevewoods, Mar 4, 2018
  8. Ryn01599
    rohnert park
    Never had the oil run low. I’ve done all my own maintenance and have been careful to change oil every 5k miles or sooner if needed. Occasional top offs from time to time but nothing major.
    The ticking was quiet at first and about a week later because louder. It’s not overbearing but can definitely be heard when driving.
    I’m in the Bay Area (about 45 min north of San Francisco) and brought it to a reputable mechanic but the time to tear in and identify the issue may cost too much. If I know what it is I can have that fixed, I’m thinking, at a lower price point. But no codes are given so I’m in the dark on this issue.
  9. Patrick Wong
    18,210
    6,513
    No codes are logged because the basic issue is mechanical. Since you observed the noise level went up abruptly, that does imply some damage has occurred to the valve train or whatever area is causing the noise.
    Luscious Garage in SF is one place you might try if you want to get another opinion about what might be wrong.
    As previously pointed out, it is possible that the valves need adjustment. That can be determined by removing the valve cover and measuring the clearances. However if that is the problem, it is not inexpensive to adjust the valves as the camshafts must be removed for access to the bucket spacers that need to be replaced. Plan on $600 or more for that work.
    Considering the engine has 200K miles on it, you don't want to put a lot of money into a repair, as the repair is not going to restore the condition of the pistons, cylinders, valves, etc.
    So, you could ignore the noise for now and see what happens, or you could try to get another informed opinion about what is wrong, or you could try to sell the car, or you could start to save the funds to have a used engine installed when the existing engine dies, etc. Good luck.
    Ryn01599 and JC91006 like this.
  10. gregT
    gregT Junior Member
    holmen
    what did you find? mine is doing the same darn thing....
    i even tried something....
    i cycled thru all injectors.. on 3rd injector, ticking stopped...
    the tick does not sound like injector related... ive heard the injector tick.. this is LOUDER than an injector.
  11. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    He hasn’t logged on for a year. I’m guessing he sold the car.
  12. sc008y
    sc008y New Member
    Lehigh Valley, PA
    I know this thread is old but this is the exact noise my car is making. 211,xxx. Noise was gentle and nearly unnoticeable at 208,xxx and was left unattended because apparently lots of noises are okay for this engine. The noise gets noticeably louder after a long trip. I know the best answer will be 'replace the engine' which I can do, but I'd love to find out the cause of this issue and fix it if possible. I might open a thread on the issue and my attempts to fix it.
  13. Richard2005
    Richard2005 Member
    161
    69
    Australia
    Did you find the cause of the problem ?
  14. ChapmanF
    18,543
    I see this is an old post, but there should be a response in this thread. It's in the Gen 2 forum, so the engine is the 1NZ, and the reason there are more people replacing 1NZs than doing valve adjustments is (1) replacement engines can be had pretty cheaply, and (2) valve adjustment on the 1NZ is crazy impractical.
    1NZ valves are adjusted at the factory by choosing each intake valve lifter to be one of the 35 available sizes for those, and each exhaust valve lifter to from among the different 35 sizes for those. At the factory, this is easy, because all 70 lifter choices are right there to be chosen on the production line.
    To field-adjust a 1NZ, you have to (1) measure all the valve clearances to determine how far each clearance is off; (2) remove the camshafts and all of the lifters, keeping them in order; (3) measure each removed lifter to determine what size it is; (4) do the math with the clearance you measured to determine what size you need; (5) order the sizes you need; (6) wait around with your car apart until they all arrive, including the one that wasn't in the warehouse and comes on the boat from Japan; (7) reassemble the engine.
    If you're in a hurry, you could order 560 lifters before you start, and try to return 544 for a refund after you're done. Not that I've heard of anyone successfully using that approach.
    Sometimes people talk about "shims" when describing that sort of adjustment. There are no "shims" in the 1NZ. The entire lifter is what comes in 35 sizes, and the entire lifter is replaced. To have a full selection of those in stock would be a mid-four-figure investment.
    Hence, a lot of people replace 1NZ engines when they wear out.
    Chris Thompson likes this.
