Can I buy this part for less than the dealer wants to charge me?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AJP, Sep 11, 2020.
  1. AJP
    AJP Member
    160
    Central Pennsylvania
    This rear panel rusted through and snapped off (it's been dicey since I bought the car in 2012). I tried using a special epoxy clay to fix it, and it held for a good two months but snapped back off today. The dealer wants to charge an *#$%*@ $400 for the part PLUS LABOR. What is this panel actually called, and can it be bought for any less than that insane amount?
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
  3. rjparker
    10,405
    6,519
  4. dolj
    dolj Senior Member
    8,516
    4,321
    Wellington, New Zealand
    Rusted? Isn't it plastic?
    #4 dolj, Sep 12, 2020
    SFO, valde3 and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I do not know ...... they use a lot of road salt in Pennsylvania. :LOL:
    All four of our Gen 2 had plastic garnishes. But I guess the screws could rust.
    As mentioned -- junkyard. There are also unpainted ones available online. I think I saw them on Ebay a while back.
  6. Travis Decker
    139
    116
    Portland OR
    I guess nobody clicked on my link. you used to only be able to get them in black cheap. Now they are available painted cheap.
    No reason to go mess around with a junkyard and get some old plastic that's just going to break again.
    If you look up the color code for your car and do a search for "Prius rear garnish" with that code you will find them online
    jzchen, jerrymildred and davecook89t like this.
  7. rjparker
    10,405
    6,519
    I clicked but thought salvage might save $50. Depends on the market and availability. Based on the pic it looks like the plastic tabs broke off. Might get a better switch as well which I had go gooey on me back in the day. The dealer might have been including that. I seem to recall the correct removal /install requires removing the inside panel.
    #7 rjparker, Sep 12, 2020
  8. AJP
    AJP Member
    160
    Thanks everyone for the response. Now that I know what the part is called, I can do some looking around on eBay for one. Yes, it was the screws that rusted through. But two of the side pieces of plastic snapped also. As far as the dealer including a new switch… If you’re referring to the lift mechanism to unlock and open the trunk, nope, that was already replaced last year for $250.
  9. AJP
    AJP Member
    160
    By the way, what is the OEM part number?
  10. Travis Decker
    139
    116
    Portland OR
    Get one off amazon oem number has to be looked up by Vin to get color. Used will just break again. Just my .02
