DIY Grid Reconditioning Charger
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abarnabe, Sep 13, 2020.
  1. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    I use a led driver to recondition my HV battery, so far with no issues.
    It has a constant 350 mA current and 257v dc output.
    I used 10 (1n4007) diodes in series to lover the voltage from 257v to 250v.
    For who's interested It's a Mean Well HLG-80H-C350A available on ebay for less than 90 dollars.
    In the black box I have placed the diodes.
    It can be used for gen3 and gen2 prius.
    #1 Abarnabe, Sep 13, 2020
    Dxta, ydpplqbd, ANDRAS RIMELY and 9 others like this.
  2. ASRDogman
    ASRDogman Senior Member
    6,063
    3,256
    I believe this will only charge the battery, not recondition it?
    How do you keep the fan running? I know it's low amperage so the battery wouldn't
    really get hot.
    How do you discharge the battery?
  3. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    I use a 12v 5a battery charger to run the battery blower, the pinout is available on prius chat, I can't post links, but you can search for gen 3 battery fan pinout.
    To discharge the battery I use bulbs by following the Prolong procedure, basically I start with 400 w bulbs, then decrease the current by loosing some of them as the voltage drops.
    Richard2005, edthefox5 and Fred_H like this.
  4. ASRDogman
    6,063
    3,256
    Well, good luck. Seems like it works for you.
    Abarnabe likes this.
  5. Fred_H
    Fred_H Misoversimplifier
    546
    473
    26
    Germany
    That power supply looks like a good basis for your DIY charger. Does it get very hot?
    Are you measuring and logging current and voltage while charging?
    I think that is unnecessary as long as the power supply is limiting the current to around 350 mA. But I'm no electrical expert, so EEs please chime in.
    I like your collection of light bulbs and sockets on the discharger.
    fotomoto likes this.
  6. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    Thanks for the feedback Fred_H , the charger has an aluminum case, it becomes warm, but never hot. I measure the voltage while charging with a meter and
    the current is constant according to the manifacturer, so I haven't monitored that.
    It is possible to change the current with a screw and the max output is 350mA. For the discharger I recycled a lot of trash I found in my attic :) Never throw away anything.
    I'm very interested about the max voltage feedback, that's the bit I was mostly uncertain about so I have tried to stay as close as possible to the Prolong charger specs.
    #6 Abarnabe, Sep 14, 2020
    edthefox5 likes this.
  7. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    I performed 3 deep cycles, I've followed the prolong balance procedure and after 14 hours the peak voltage was 238.6, then after 10 hours it slowly dropped to 236v is this expected?
    I can confirm the battery capacity improved, before reconditioning it went from 4 to 3 bars in seconds, while now it takes a minute or more.
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Maybe this:
    "Once the battery becomes ‘full’ the balancing process will begin. During the ‘balancing’ phase you will most likely see a steady voltage reading or a very slow oscillation of voltage – perhaps a 1-3 volt swing over several minutes. This means the battery is in the balancing phase"
    Prolong Hybrid Automotive Battery Charger User Guide | Hybrid Automotive
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Mine did the exact same thing when I did my first reconditioning with a prolong. I discharged down to 80 volts and then started charging. Charged it for about 30 hours. It was at 236 volts.
    3 years later after another discharge and multiple charges it never got above 236 volts again. It ran really well for 3 years and still had not failed or thrown a RTOD when I finally just recently bought a NPB system and swapped those cylindrical cells into the box.
    So i would say don't worry about it and I applaud your bench skills. But 14 hours may be not enough time try 30 hours then it will get a nice balance phase. I was using 14 hours and the 30 hours was a marked improvement after i was advised here to extend that time. 356 ma is very low for that big pack. Takes a long time.
    And I just sold my old G2 battery's for $100.
  10. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    I will try a 30 hours charge thanks for the tip edthefox5. I wanted to recondition the battery after I noticed a sudden capacity drop in August during my holidays.
    I came down a very steep and long alpine pass in Austria the Gerloss pass, the battery was at 9 bars ( 8 + the 2 tips on top), I parked the car in full sun on a lake, than after 2 hours I went up a very steep road in reverse and fully loaded with bagage and 5 persons, the ice didn' t kick in to help as it usually does, strange I thought.
    I drove a few km and the battery went back to 6 bars, but then after many km downhill I've never managed to get 9 bars anymore and it went from 4 to 2 bars in seconds, I thought I killed it.
    Leaving a cold battery fully charged in the sun and then squize it to full load is really bad and I was fearing there was no way back, until 2 days ago the reconditioning reversed the capacity issue.
    I still have to test if it goes back to 9 bars, but for that I have to wait until I drive back to an alpine road next month.
    ANDRAS RIMELY and edthefox5 like this.
  11. ASRDogman
    6,063
    3,256
    WHY would you drive UP a hill in reverse? The engine doesn't charge the battery when you're in reverse.
    edthefox5 and Grit like this.
  12. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    I did it just for 5 meters to get out of the parking, but it was a really steep off road parking spot.
    ANDRAS RIMELY likes this.
  13. ASRDogman
    6,063
    3,256
    Oh, you made it sound like it was miles or so... :)
    Linqhao and Abarnabe like this.
  14. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
    ydpplqbd and ANDRAS RIMELY like this.
  15. edthefox5
    10,096
    4,804
    Clearwater, Florida
    I don't own a G3 so not sure can you power brake the car and charge the battery like in a G2?
    Put it in D foot on brake and then push the gas down until you see the charging battery arrow going into the battery on the energy monitor. Not much past idle really. I was doing that for a long time to prop up my battery. It helps.
    I think I remember something about you can no longer do that on G3. I was doing that at almost every light towards the end there.
  16. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    The parking brake police gonna come and getcha.
  17. Mendel Leisk
    38,653
    Maybe obvious to all present, but anyway: driving in reverse only uses the battery for motivation.
    ANDRAS RIMELY and ASRDogman like this.
  18. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Are the diodes necessary? Would the extra 7 VDC (257 vs 250) be problematic? It’s such a small difference.
    < 3%
  19. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    probably not.
    #19 Abarnabe, Sep 19, 2020
  20. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    Probably not a biggie. According to wiki nimh cells need between 1.4 and 1.6v , the higher the current the higher the voltage, and 257v is between those values, but I' going to remove half of them and see how it goes, not all of them, because last time I did a 24 hour charge i have noticed some swelling which scared me a lot . After an hour the swell went away, is it expected?
    I did 2 load tests on each module with a 12v 115 w bulb for 1 minute before the reconditioning and found that 2 and 12 were consistently the weakest, because the voltage drop was 0.30v on top of the others, but some modules gave inconsistent results.
    Instead I would like to measure internal resistance of each module, deep cycle only the ones with the highest resistance and leave alone the other ones, this should bring more balance.
    #20 Abarnabe, Sep 19, 2020
    tvpierce likes this.
