Struts - After Market Parts vs. Toyota Parts
Discussion in 'Gen 3 Prius Main Forum' started by Isola J, Sep 15, 2020.
  1. Isola J
    Isola J New Member
    Chicago
    a newbie here with auto mechanical knowledge in the zilch range. I have a 2010 Prius with about 60K miles, but thinking needs new suspension, especially in the front. I was given an estimate of $1,600 for new struts in the front with Toyota parts, and was told that it's not even worth considering aftermarket parts. Another shop gave me an estimate of about $1,000 ($369 per strut, the links at $40 each and labor cost), which I am deducing is for the price of aftermarket struts. My question is: are aftermarket struts so inferior as to not worth considering using? Any reasoned/knowledgeable feedback will be greatly appreciated.
  2. Solar Blue
    Solar Blue Member
    58
    28
    Columbia River Gorge
    Good question. You can't really go wrong with OEM parts. Aftermarket parts can be great or horrible. It depends on the manufacturer and what you want to achieve. Do you want to restore the original ride? Do you want a sporty ride? A softer ride? Lots of options. Youtube might help you with that decision.
    The prices you were quoted all seem high. And FYI, you could buy the OEM parts and have any shop you trust install them. You'll need an alignment, too.
    But, at 60,000 miles the car should not need new struts unless it has lived a very hard life.
    I recommend taking it to a few reputable shops that specialize in front end and alignment work. Maybe pay for a full inspection.
  3. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    Short term/about to sell the car: aftermarket. The real cheap stuff is typically very low quality.
    Long term: OEM. If you don't like the pricing, keep searching. These are not speciality items that only the dealer should be entrusted to install.
    GOOD LUCK!
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    CC854187-3CF8-4166-826C-ADF5E10523F4.png I Try KYB shocks. They are Japanese manufactured and excellent quality. They are probably the best, moderately price shocks on the market.
    Rayman2010 likes this.
  5. Prius Envy
    Prius Envy F U R Y
    So Cali
    I have KYB on my 2011. I forgot the exact cost, but far lower than $1,000 installed.
  6. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    OEM are good quality, but are way overpriced. I don't know what company makes the Toyota shocks and struts, but I have a suspicion that it's KYB.
    If I had to replace my suspension I would use aftermarket parts... but there are only two aftermarket brands I'd consider: KYB and Bilstein. It appears Bilstein doesn't make shocks/struts for the Prius, so it would be KYB.
    Under no circumstances would I put Monroe, Gabriel, Napa or any other aftermarket shocks/struts on a vehicle I own.
    Solar Blue likes this.
  7. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I replaced my struts with KYB Quick Struts. I think $500 for the whole set and I replaced them myself. Very straight forward and took me about 2 hours to replace all 4 corners. Not bad at all!
