Prime rear window exterior trim.
Discussion in 'Prime Accessories and Modifications' started by Rodney.E, Jun 4, 2020.
  1. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    That never happened on my 2017 Prime, so I don't think it will happen to the 2020 Prime. The bottom gap is a minor annoyance for me. But the top gap is major concern when the sheet of ice on the roof get broken off and get caught in the hinged area. For that reason after a major ice storm like the photo below, I never open the hatch door until all the ice are gone.
    jerrymildred and Rodney.E like this.
  2. Tideland Prius
    16,155
    Yeah. That’s the bottom of the drain the top is on the other side of the rear spoiler.
    jerrymildred and Salamander_King like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    That left picture could be my car 90% of the time except for the paint color. :whistle: I admit that it bugs me, but I don't sweat it. If I had to deal with ice, though, I'd be just as concerned as you.
    The thing is that it seems like if I brush or blow the leaves out of that area, most of them go into the car no matter which way the wind is blowing. :mad:
    Salamander_King likes this.
  4. Brent nishimoto
    Brent nishimoto New Member
    2020 Prius Prime
    My guess would be that capillary action is our worst enemy with this issue. The more stuff we put into the glass joint, the more small crevices will be created and therefore more opportunity for moisture to accumulate. It ain’t broke. Just dirty. High pressure water gets my vote!
  5. Rodney.E
    Rodney.E New Member
    22
    17
    Ohio
    2018 Prius Prime
    I may have a solution for the top gap. I got some of this trim off amazon and pre fit it. It would be perfect if it was about 3/32 smaller. It folds downward but honestly that wouldn’t bother me. It smashes a bit on the seal when the hatch is opened. That may help in the long run. My only concern is the matt black. I’m going to try to hit it with some WD 40 and see if it will shine it a bit. Also works on my F-150 that looks like it has a floating window that builds up pollen and looks moldy fast.
    What do y’all think?
  6. Salamander_King
    10,975
    8,867
    New England
    Yeah, if that fit in the gap and would not come off, then that is a winner. Do you have a link? From your picture, it looks to be a simple "C" shaped molding. I hope one of the trim pieces I ordered will also work. I will let you know in a week when I get them.
    Rodney.E likes this.
  7. Rodney.E
    Rodney.E New Member
    22
    17
    Ohio
    2018 Prius Prime
    Sorry got busy for a bit. Trying to add link here. Let me know if it goes through right.
    XuSha 1.7 M 5.6FT Universal Car Front Under Windshield Panel Sealed Trim Moulding Rubber Seal Strip Weatherstrip
  8. Rodney.E
    Rodney.E New Member
    22
    17
    Ohio
    2018 Prius Prime
    I haven’t had a chance to see if I can get it more gloss yet but if I can, I was thinking of using a tad of slow dry hot glue inside the trim where It hits the glass.
  9. Salamander_King
    10,975
    8,867
    New England
    Thanks for the link. That looks similar to one of the molds I ordered but a bit smaller in all dimensions. The top pic is from your link, the bottom one is the one I ordered. I will see how the one I ordered works and if it is too big, then maybe try yours.
  10. Rodney.E
    Rodney.E New Member
    22
    17
    Ohio
    2018 Prius Prime
    What size do you all put for pics when you upload? I just looked at mine and damn! You can’t even see them lol!
  11. orenji
    orenji Senior Member
    5,884
    3,486
    If you click on your pictures they open up full size. Can see them fine.
  12. Rodney.E
    Rodney.E New Member
    22
    17
    Ohio
    2018 Prius Prime
    Ok sweet, thanks! On my phone they look small and pretty distorted.
