Prius life after 100000 mileage
Discussion in 'Gen 2 Prius Main Forum' started by asaini, Jul 10, 2005.
  1. cid404
    cid404 Junior Member
    I'm currently on a 2002 Prius, with just over 105,000, and no major
    problems.
    Other than the standard recalls (and tires, etc.) the only problem I had
    to deal with was a stuck seatbelt in the back seat (it wouldn't retract).
    This is the first car i've ever had in which I've never had to replace the battery.....;)
    Although I'm starting to lust after the 2007 Prius or Camry...
  2. ecprius
    ecprius Junior Member
    26
    Livermore, CA, USA
    <div class='quotetop'>QUOTE(efusco @ Oct 11 2006, 08:44 AM) [snapback]331160[/snapback]</div>
    Funny, too, because he answered the first time back in April. :p
    Had to have been all that driving!
    - Ed
  3. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Almost,
    I put 88k on my 04 with no major issues. It was actually getting better mileage (50mpg) then my new 06 (48mpg-now up to 51mpg after 13k).
    My only issue was the AM radio reception and one rear wheel bearing(due to alignment problem from factory). I used Mobil 1 after 5k miles. Tires lasted 40k.
  4. BeachDriver
    BeachDriver New Member
    I just had my 2001 Prius serviced yesterday. At 135,000 miles! I needed new front brake pads, front tires and alignment, and a normal interval service. But besides that, the car is still solid, (well as solid as a classic Prius). :p
    It's my daily HOV lane driver and has served me very well!
  5. JeffG
    JeffG New Member
    94
    Middle Tennessee USA
    <div class='quotetop'>QUOTE(BeachDriver @ Nov 21 2006, 06:39 PM) [snapback]352776[/snapback]</div>
    Was that the first time the brake pads had been replaced?
  6. FishHawk
    FishHawk New Member
    176
    <div class='quotetop'>QUOTE(JeffG @ Apr 5 2006, 05:08 PM) [snapback]235462[/snapback]</div>
    For what it's worth. I work at an auto auction and have only seen 5 Prius on the lot probably 04. Not too shabby. Most of the cars I drive for the auction are real Sh%*tboxes. FishHawk
  7. Gen2
    Gen2 Member
    319
    My wife has a customer that purchased a new Prius this Feburary and now has 100,000 miles on it. She has had no problems with it and told my wife this week that if she ever does wear it out that she will definitely get another Prius.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(Gen2 @ Nov 24 2006, 09:25 PM) [snapback]353850[/snapback]</div>
    Holy cow! 100K miles in less than 1 year? I'd be curious to know if the customer is still on the original brake pads and shoes.
  9. swwalker
    swwalker New Member
    Hopewell Junction, NY
    Just hit 100k miles with my 2004 Prius. Bought it in May 2005. No major probs. Minimal maintenance. Best thing I ever bought. Only problem right now is smart key does not open driver door sometimes...
  10. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I just hit 122k on my 04. I now drive 35k miles a year. It's has never been to the dealer for service. I change the oil every 15-20k miles. 3 sets of tires and 3 air filters is the extent of the self service that I have given it. Still drives as good as the day I got it.
  11. hill
    8,812
    300K ??! But ... but ... Mr Spinela's dust to dust report said the Prius only goes 100K as opposed to Hummers that just keep going & going & going. I'm so confused :D
    BTW, Holy antique threads ! ! ! How'd this nearly 3yr oldie get resurected.
  12. grlong
    grlong New Member
    Have an '04 with 115K miles. Received a software patch in late '04. Otherwise no problems - original brake pads, 2nd set of tires, oil changes every 5K miles. Use it primarily for long haul commuting. It has been a great car.
  13. Lcruiser
    Lcruiser Junior Member
    77
    What kind of oil are you using? I think you should at least give your Prius 7K-10K oil change interval if not 5K. Why 15-20K miles?
  14. tochatihu
    tochatihu Senior Member
    9,791
    3,772
    Kunming Yunnan China
    2001 Prius
    From separate conversations, I understand that krousdb uses Mobil 1 0W20. On such a long run, it certainly seems wise to see if there is any TBN left :) We are working on him to get into used oil analyses, because these change intervals are unusually long for Prius.
    I wish he'd do more air filters, but not the boss. Main point of the post was probably to indicate that Prius can be a *very* low-maint vehicle.
  15. Red Five
    Red Five Red Five
    Orlando, FL, USA
    My '04 has over 102,000 miles and not one problem thus far. Regular oil changes (at 5 K miles) and that's it. MPG still averages 45 in combined driving like it has from the beginning. By far the most reliable and efficient vehicle I've ever owned.
  16. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Major milestone today; I just joined this li'l club.
    ... still in extended warranty ... still in extended warranty ...
    ... still under warranty ...
    POOF!
    [well, the 120 or 150 k or whatever it is hybrid system coverage is
    still in effect, in theory..]
    To be fair, not all of those miles are mine, as I got the car gently
    used at about 13K, but it's still a milestone. It came right around the
    I-93 x I-495 interchange north of Boston, not too far from where I saw
    50K and 90K. With the car pulling 61.8 MPG average at half the tank
    gone in weather probably averaging about 32F, it feels just nicely
    broken in. Still plenty of meat on its second set of tires, and I am
    *so* not worried about brake linings at this point.
    _H*
  17. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Hobbit,you're very naughty,taking photo's at 59 and 56MPH,TUT TUT,:D
    Anyways i'm going to give my Prius Taxi it's 210,000klm service tomorrow....weather permitting!!
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I notice the photographer had to slow down to get rid of the tremor.:D
