CHS stop vehicle in a safe place.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Potorap, Sep 15, 2020.
  1. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hello everyone,
    I had the check hybrid system stop vehicle in a safe place alert. Checked 12 volt battery and had corrosion on negative cable and post. Remove and cleaned, charged battery and tested, it failed, replaced battery. Code remains. Car does drive but acting lethargic.Car charges and shuts off upon completion. No mph while driving, shows 0 mph.No code seen with a regular scanner. Any advice besides taking to dealer?
    #1 Potorap, Sep 15, 2020
    48,945
    oh no!!!:eek:
    Potorap likes this.
  3. bisco
    48,945
    you can check the cooling fan, but i think your gonna need tech stream.
    maybe try dr prius or other phone app?
  4. Potorap
    345
    148
    Pahrump, Nv
    Thank you Bisco.
  5. bisco
    48,945
    hybrid assistant and torque are other reader apps. all the best and please keep us posted. i hope it is something simple, i wonder if anything in the engine department could throw the hybrid system message, like an o2 sensor or something.
    Potorap likes this.
  6. Potorap
    345
    148
    Pahrump, Nv
    Any recommendations for a quality Bluetooth OBD II adapter? I’ve read cheap ones can cause issues.
  7. bisco
    48,945
    i have never used one. try searching here, or go with recommended for the app you buy. the only problem i recall is leaving it plugged in all the time
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    OBDLink LX will read just about anything. Carista will handle anything a Gen 3/PiP will throw at it. I have both. There are lots of other good ones discussed here on PS as @bisco mentioned.
    Potorap likes this.
  9. Mendel Leisk
    38,207
    Do you know the code?
  10. Potorap
    345
    148
    Pahrump, Nv
    Yes, the code is 0129. Brake system control module has lost communications.
  11. Potorap
    345
    148
    Pahrump, Nv
    Thank you
  12. Potorap
    345
    148
    Pahrump, Nv
    UPDATE
    Well, I bit the bullet today and had my Pip towed 60 miles to the Toyota dealership. Just got the call that they found out the skid control ECU is bad.
    Quote is about $2k.
  13. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Is that the same as ABS? Because, the antilock brake systems usually work independently, and as such, you may be able to drive the vehicle without issue, other than no ABS.
  14. Potorap
    345
    148
    Pahrump, Nv
    I’m not sure.
  15. Gary RZ
    Gary RZ Junior Member
    Charleston
    My wife ran the gas to empty then limped to the gas station for a fill up. Several days after it shows this stop in safe place code after running fine for a few days. I'll be watching this thread but feel like I see a trip to the dealer. Tried the 'pull the red plug thingTried charging battery by pluging in but got same error code with addn't not charging notice. noticed a little corrosion around the 12 volt terminals, does that affect the recharge system?
  16. Potorap
    345
    148
    Pahrump, Nv
    Hello, what is the code your getting? IMHO I believe the 12v battery had something to do with it in my situation. The service writer told me it has 180k miles and that’s the reason. Not sure what to believe. This is the only issue I have had with my PIP. I’m very satisfied!! Good luck with your vehicle, wish you the best. Keep us posted please.
  17. bisco
    48,945
    sorry to hear it, but better than a bad battery cell i suppose.
    skid control ecu might be covered here. try search, hopefully, it is a simple repair with a salvage part.
    a dealer quote for 2k is often a few hundred for the savvy diy'er.
    you might want to post a new thread with that header in gen 3, it's probably the same thing, and might attract some of the experts here.
    Yea Right and Potorap like this.
  18. Potorap
    345
    148
    Pahrump, Nv
    Thanks Bisco, I’m beyond that point now. Car is at dealership waiting on part, due tomorrow. From what I researched it would need to be programmed as well.
  19. Potorap
    345
    148
    Pahrump, Nv
    76703ACD-F1BA-4C12-9365-6783A9C12D41.jpeg Update, picked up car today. Happy with the results. Asked the service writer to give me the failed part. I’m adding pictures of part.
  20. Potorap
    345
    148
    Pahrump, Nv
    E1465954-F1D1-4642-B9F0-8D55295FBB53.jpeg Here is another photo. Thank you everyone for advice given.
