So, do you like gen 4 Prius?
Discussion in 'Gen 4 Prius Main Forum' started by aswarola8, Sep 20, 2020.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I have a Prime. I really wish I could see my brake lights while braking. :ROFLMAO:
    kithmo and alanclarkeau like this.
  2. A5B1
    A5B1 Junior Member
    ft myers, fl
    2020 Prius
    I own the 2020 4.5 gen and like it more than any of the previous generations. I have owned a 2006, 2010, 2016 and 2018 and now my 2020 which is the best.
    jerrymildred and Tideland Prius like this.
  3. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    To be clear...my daily driver is a 2015 Prius IV, but drive my 2019 Corvette ZR1, 3ZR, ZTK, A8 quite a lot. Every tool in my box serves a different purpose. That said, Toyota better fix the "look" of their upcoming Prius models or I will rotate out when the 2015 is replaced.
  4. Mendel Leisk
    41,824
    Were you in ECO mode, that'll make make for maddeningly passive-aggressive throttle response, harder to modulate. I stick with "regular" (neither ECO nor PWR).
    I understand with 4th Gen the three modes have all been shifted, roughly one mode, in the direction of PWR?
  5. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Mendel: I have compared gen 2, 3, and 4, and yes, always using the "ECO" mode. In the 2 and 3, I found it very uncomfortable, having to push the go pedal halfway down prior to any response. What you're saying makes sense, because the "ECO" mode in the gen 4 feels like a normal throttle. I never use either "regular" or "power."
    jerrymildred and Mendel Leisk like this.
  6. jerrymildred
    11,517
    14,157
    Tampa, FL
    I especially like keeping the Prime in ECO when at low speeds. Much finer control of the m/kWh indicator.
    alanclarkeau likes this.
