Will there ever be a firmware update for the 2018 Prime Plug-in?
Discussion in 'Prime Main Forum (2017-2022)' started by jdb2, Sep 28, 2020.
  1. jdb2
    jdb2 Junior Member
    Westminster, CO
    2018 Prius Prime
    I ask this because I have a loved one who owns a 2018 Prius Prime Plug-in with all the bells and whistles and I've noticed many irritating problems.
    ( Note that the firmware version hasn't changed from what I posted in this thread )
    I often ride with said loved one or drive the car with said loved one in the passenger seat ( usually when we go out to hike etc. ). I've noticed that the Bluetooth audio is abysmally poor in quality, so, I have to plug my iPhone X directly into the car's USB port. In addition, irregardless if my iPhone is connected to the car via Bluetooth or USB, *the album artwork of whatever is playing is almost never displayed*. Furthermore, the head unit often sporadically disconnects from my iPhone and/or displays a "USB error" message. Even worse, the head unit will sometimes spontaneously reset, plus, I often have to manually reset it several times to get my iPhone recognized -- I never have any of these problems with any other devices to which I connect my iPhone.
    Also, and not related to music, when I try to charge my iPhone via the Qi inductive charger under the head unit, the phone will briefly indicate that it's charging, and then the charger will disconnect and start to flash every few seconds with three brief yellow blinks. I have an "Anker PowerWave 7.5 Fast Wireless Charging Pad" at my house and my iPhone never has a problem with that. I'm quite miffed that a $35K+ car can't seem to charge my Qi compatible iPhone X. Note that I do have a quite thick LifeProof "FRE" case on my iPhone, but my Anker charging pad has never had any problems with it.
    I was wondering if there is ever going to be a firmware update that might solve the aforementioned problems, assuming they're not insoluble via a firmware update due to hardware problems or incompatibilities.
    Regards,
    jdb2
    TGrracie likes this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,580
    1,601
    Somewhere in Wisconsin
    2013 Chevy Volt
    Very unlikely
    and if they do you will need a TSB and $$$
  3. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,157
    Chicagoland
    2018 Prius
    Does the phone charge if you take the case off?
  4. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    All of the problems you mentioned are well know issues mainly with larger 11.6" HU on any year model of Prius Prime. Except for the frequent re-booting problem, firmware update even if it exists is not likely to solve the problems you mentioned. Bluetooth audio quality, I think, is inherent to the connection. The same sound source either by the BlueTooth or direct USB connection, the direct connection always sounds better. The album artwork of whatever is playing is almost never displayed on purpose. It is a safety "feature" Toyota implemented to only allow seeing the album artwork if you have your car in Park, never when the car is in motion. iPhone disconnecting from USB has been reported, but I don't think any firmware update has solved the problem. And Qi charger in PP is so weak as to it is totally inadequate for today's power-hungry smartphones. You are much better to just plug in high wattage USB-C PD car adapter. I use a 63W PD adapter, and my Pixel phone can be charged in less than 20min from almost 0% to full.
    #4 Salamander_King, Sep 28, 2020
    yaun and Tips like this.
  5. bisco
    48,969
  6. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    I have the small screen, and I guess I've never tested wired audio. I just went for a short drive to try it. Since my phone is android it didn't work with the USB connector.
    I tried switching between an aux cable and bluetooth. The aux cable sounded a little better, but it was hard to tell for sure. Probably not better enough to notice while going over 45mph, and probably not enough to be worth the downsides. But I have the base audio system, so maybe it's more noticeable with the upgraded one.
    I have one of those stupid phones without a headphone jack, so to make it as convenient as bluetooth I'd need a wireless charger to charge the phone while playing music, and a phone mount to let me switch tracks on the phone instead of the steering wheel buttons.
    I'm thinking of adding a wireless charger anyway. The "phone cubby" is too slippery and too short. If I just set a wireless charger in it, it would level it out with the front of the cupholders, and hopefully it would have a grippy surface.
  7. Elektroingenieur
    2,515
    3,253
    Three Touring
    There have been several updates for the navigation receiver assembly (head unit), but I don’t know if they solve the specific problems you’ve mentioned. At this writing, the latest one is described in Toyota bulletin T-SB-0031-20, “Audio Head Unit Software Update (Denso)” (PDF), April 1, 2020.
    If the car is still under warranty, a dealer could install the update at no charge; I recommend this option, since if the update were to fail, replacing the head unit would be costly. The files are also available with a Professional Diagnostic subscription to techinfo.toyota.com (from $65) and, perhaps, from the securedp.toyota.com website, which may or may not have the latest version.
    As for the wireless charger, I don’t think anything has changed since my January 2019 posting.
  8. Leadfoot J. McCoalroller
    6,833
    6,478
    Pennsylvania
    2018 Prius c
    Order another Anker charger pad, affix and wire it to your vehicle, and enjoy the result.
    It's been proven many times over- automakers are not keeping up with the pace of smartphone product technology. Frankly I think it's embarrassing that they still try, rather than play nice hosts to standardized field-upgradable modules.
  9. EV Happy
    EV Happy Member
    68
    40
    I just wish they would update their maps. Google maps on the phone are so much better.
  10. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Thanks for posting that. I was wondering. My HU is E7051 and it has none of the issues that have been plaguing so many Primes. I haven't checked the software version, but there's no record of it getting updated before I bought it two years ago. Is there anything to be gained by doing an update? I'm in the "If it ain't broke ..." camp, so there would have to be some improvement for me to spend the money and time on something that could cause more trouble than it cures. But if it'll boot faster or add features, I might give it a shot.
    Elektroingenieur likes this.
  11. Elektroingenieur
    2,515
    3,253
    Three Touring
    I don’t think so. The service bulletin announcing the updates applies only to vehicles with one or more of the listed problems; it’s not a recall or service campaign that applies to all vehicles. If yours is working, I’d leave it alone.
    jerrymildred likes this.
  12. jerrymildred
    11,491
    14,100
    Tampa, FL
    Thanks. I hadn't read anything anywhere about added any functionality but wanted to be sure. Mine has never exhibited any of the stuff the update claims to fix. In my case it would be, at best, a waste of time and money.
