Automatic Braking on Technology (BRAKE!)
Discussion in 'Gen 4 Prius Main Forum' started by Leo, Oct 13, 2020.
  1. Leo
    Leo Leo
    81
    Ottawa, Canada
    Twice recently my 2018 Prius Technology Edition has slammed the brakes on me, in the middle of a highway at highway speeds. I think I know why: the onboard radar system misinterpreted the traffic ahead.
    In both cases there was a car crossing in front of me perpendicular to the road I was on. In both cases when I was at least 100 yards from the car crossing in front of me, my Prius slammed the brakes on me, endangering the car right behind me. It also displayed the word "BRAKE!" in a large red panel on my dashboard. (If the car is already braking on its own, what purpose is served by screaming "BRAKE!" on the dashboard???)
    In my judgement the car crossing in front of me would have been long out of my way before I got dangerously near it; however, the computer considered that the other car was a stationary obstacle on the road because it was in front of me, and not receding or approaching me. The computer misidentified it as a stationary obstacle in front of me, not recognizing it as moving from left to right. Had it been stationary I would have T-boned it, but it was not stationary. Had the car stopped in front of me, truly there would be call for emergency action, but that would have caused me to steer around the obstacle.
    I would recommend to Toyota that this system be modified to recognize if a presumed obstacle is moving sideways to me out of the way at a speed that predicts it will be out of way by the time I get there. Of course if the object is not moving left or right, or if it judges that there is no room for steering around the presumed stationary obstacle if it stops moving, then automatic braking is called for if I don't start braking. As it is, the risk of a tailgater colliding with me from behind because of automated emergency braking is higher than the risk that I would collide with the vehicle moving out of my danger zone.
    In other words, the computer braking system should act the way an alert, competent driver would act.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    That's really odd. The "BRAKE" sign, when operating correctly, will come on for at least a short time BEFORE it slams the brakes on.
    But it does prime the brakes for a MASSIVE stop if necessary and when you touch the brake pedal it will act instantly and savagely.
    But "at least 100 yards" - I would hazard that it hadn't even seen it at that point. It must have been something else which put the wind up it.
    Maybe you need it checked. Are all your sensors clean?
  3. CooCooCaChoo
    CooCooCaChoo Active Member
    888
    494
    Cow-lee-fornia
    2023 Prius
    When the car "sees" something ahead with the radar, it would display it on the screen in the dash. Do you recall if that came up on the screen before the BRAKE message?
    I have never had my Prius slam on the brakes on the highway at highway speeds regardless of the amount of traffic or whether they were moving it in or out of my lane.
    Something is definitely funky with the radar.
    Tyfly and alanclarkeau like this.
  4. alanclarkeau
    7,041
    7,580
    I have had the "BRAKE message" twice on the HIGHWAY though. One where a motorbike crossed across in front of me much too close through the gap which didn't exist between me and the car in front (on RADAR CRUISE at the time). The other just recently, when a UBER didn't see me and came into the "non-gap" in front of me.
    In both cases, I touched the brakes as the message came on, and they were savage.
  5. fuzzy1
    10,045
    Does this model use optical detection, or just radar?
    ** A simple radar system can measure speeds only receding or approaching, it cannot measure cross speeds. It would need either an optical camera system, or a more advanced rotating/sweeping scanning radar to measure cross speeds.
    ** Even if it does know the cross speed, for safety reasons it cannot assume that an object will continue moving out of the way, because occasionally (if very infrequently) the object will stall or halt to avoid hitting a newly found obstacle in its own path. The system must allow for this possibility, and begin stopping in sufficient time to avoid a collision.
    Too many drivers assume the path will clear and thus don't begin slowing down, instead cutting it very very close. This is an unsafe driving practice, and sometimes doesn't work out as expected.
    If you are not slowing in time to avoid other emergency action, possibly leading to a quick and possibly ill-considered lane change (far too often misjudged), then you are exacerbating the hazard.
    I would recommend a defensive driving refresher class for the pilot.
    Collision avoidance systems will advance in future revisions with better hardware (and software too), but that is not what you have in this car.
    #5 fuzzy1, Oct 14, 2020
    jerrymildred, kithmo and Tyfly like this.
  6. alanclarkeau
    7,041
    7,580
    But - would either of these happened at "at least 100 yards" as happened to the OP?
  7. fuzzy1
    10,045
    Very many people's judgements of distance on the road, as expressed in common measurement units, are notoriously inaccurate.
    If it was close enough that his considered emergency action was already to steer around because of lack of stopping distance, than it was obviously too close.
    Remember also that from an overall community health perspective, a square-on rear-ender is less lethal than a T-bone. And as more and more vehicles deploy effective collision avoidance systems, the frequency of sudden rear-enders will drop proportionately.
    #7 fuzzy1, Oct 14, 2020
    jerrymildred likes this.
  8. Elektroingenieur
    2,515
    3,253
    Three Touring
    Fourth-generation Prius cars built in 2018 have the Toyota Safety Sense-P system, which uses a monocular camera and millimeter wave radar; the latter has a phased array antenna for electronic scanning. As a paper about the system (Ono, R., Ike, W., and Fukaya, Y., “Pre-Collision System for Toyota Safety Sense,” SAE Technical Paper 2016-01-1458) explains, the scanning (± 25° in the horizontal) helps to detect crossing pedestrians.
    The paper also describes some of the system’s countermeasures against rear-end collisions, a hazard of which its designers were well aware. For example, TSS-P applies “a slight deceleration of about 0.7 m/s² before” pre-collision braking, lighting the stop lamps to warn other drivers. Indeed, Toyota did tests in a driving simulator, showing how this reduces the braking time of a following vehicle; the paper includes a plot of the observed relationship. The system also does feedback control of the deceleration, so the braking force doesn’t have to be much greater, or the stopping distance much shorter, than actually required to avoid a collision with the detected target.
    #8 Elektroingenieur, Oct 15, 2020
    jerrymildred, alanclarkeau and fuzzy1 like this.
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Optical too from a camera above the rear view mirror.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    At a highway speed of 70mph it would take only 3 seconds to travel 100yds.
    Assuming you're not taking any evasive action like easing off the gas, braking or steering away from the object, I don't think it's unreasonable for the car to think you're going to hit something that may have been within its detection area for 3 or 4 seconds as it crossed it.
    If the car crossing in front had stalled, then your thinking distance and braking distance would probably be longer than 3 seconds by the time you realised that it had stalled.
    Tyfly, jerrymildred and fuzzy1 like this.
  11. mitcheli
    mitcheli Junior Member
    39
    2018 Prius Prime
    I had this happen once on the highway when my car detected a tire that was on the shoulder and slightly protruding into my lane. If this happens and it’s a false detection, or something you can control and don’t need TSS-P to manage, you can very lightly tap the brakes and that should acknowledge the signal without causing you to come to a flying halt. Steer slightly away from whatever it’s detecting. Also, you can adjust the sensitivity of TSS-P if it’s flagging too often. As for sensors being dirty, that’s conceivable. Usually dirty sensors will flag an alert and let you know that TSS-P is disabled until you clean the sensors.
    tucatz and krmcg like this.
  12. CooCooCaChoo
    888
    494
    Cow-lee-fornia
    2023 Prius
    Come to think of it, the only time I have it happen is if I'm going into a curved section of roadway and there are bicyclists in that curve. The car will start to brake then, BUT not display the BRAKE message.
  13. vvillovv
    vvillovv Senior Member
    3,536
    1,245
    NY
    I don't have rear traffic sensors. It still sometimes looks like Safety Sense on the MID shows when cars are approaching from behind. The one false positive I noticed - which I'm not clear I fully understand what the computers were detecting - was at 40 mph on 4 lane road approaching a curve of perhaps 20 degrees.
    No traffic in front or behind going in my direction. 3 or 4 cars approaching going in the opposite direction and the MID displayed the Car in Front graphic. The graphic I see when in dynamic cruise in the prime is approaching a car in front of me. I looked around to try to see what the sensors were picking up and the only thing that made any sense to me anyways was the cars approaching from in front, but going in the opposite direction.
    I usually now hold the cruise button in until I get regular cruise, since I don't want to have to play around with changing safety sense setting and possibly forgetting which setting I have it set to. Even though it only takes a couple seconds to change the setting using the steering wheel button.
    #13 vvillovv, Oct 16, 2020
  14. alanclarkeau
    7,041
    7,580
    I've only used "regular cruise" once - turned it off after 2 minutes, went back to RADAR Cruise which I use all the time. It works well. Only time it doesn't is in very heavy rain, where it's blind to cars.
    Tyfly, kithmo and Prodigyplace like this.
  15. vvillovv
    3,536
    1,245
    NY
    I don't mind using dynamic cruise, I've used it a lot since getting the car. I really like the braking feature when holding the stick down for about 5 seconds the cruise will regenerative brake fairly stiffly down to around 32 mph from whatever speed the car is set at. I just prefer the regular cruise for how and when I use it.
  16. Prodigyplace
    11,696
    11,317
    Central Virginia
    #16 Prodigyplace, Oct 17, 2020
  17. alanclarkeau
    7,041
    7,580
    That's odd - it's not on mine. I have to do a long press on the button at the end of the stalk to bring it in - then next time it's back to DRCC again.
    kithmo likes this.
  18. Prodigyplace
    11,696
    11,317
    Central Virginia
    You are correct and I was mistaken. It has been a while since I referred to the manual for the car.
    alanclarkeau likes this.
  19. vvillovv
    3,536
    1,245
    NY
    Anyone ever use that DRCC stick brake? stiff regenerative braking like a tesla with regen set on Plaid..
  20. A5B1
    A5B1 Junior Member
    ft myers, fl
    2020 Prius
    I had this happen to me once on a secondary road and once backing up on my 2020 LE ,prius. In both cases, the brake warning sign came on the screen several seconds before the brakes activated, and I was not paying attention while talking to my wife. There might have been an accident w/o this wonderful safety feature.
    Prodigyplace and Tyfly like this.
