Any carista users on gen 4?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 4thgen1st, Mar 14, 2016.
  1. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    Do you think a shorter annual or monthly subscription is also not limited to a specific model of car? For example, if I buy a 1-month subscription, can I use it on multiple models of the paid apps (advanced diag and customization)?
    #141 Salamander_King, Oct 22, 2020
  2. krmcg
    2,592
    2,388
    Whittier, CA
    I have always thought so.
  3. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    From Carista:
    Hello,
    Thank you for your interest in Carista.
    The beauty of Carista is that when you have the PRO version you can use it on compatible cars without the need to purchase different licenses for different brands or markets.
    We always invent new tools that work on more and more cars. You can always check if your car is compatible: Carista OBD2 supported vehicles | See what’s available for your car - Carista
    You can use Carista on your cars, your friends cars and so on, with only 1 PRO license.
    All changes that you have made during the PRO version are saved in the car and will remain active regardless if you continue purchasing Carista or not. You just wont be able to make new changes.
    Please, do not hesitate to let me know if you need more assistance.
    krmcg and Salamander_King like this.
  4. krmcg
    2,592
    2,388
    Whittier, CA
    good to be a pro...
  5. 2020XLEAWD
    2020XLEAWD Member
    85
    42
    City of Angeles
    2020 Prius
    XLE AWD-e
    I was able to modify everything I wanted in Carista except for one annoying thing. The damn leave your car with the key and the car still on beeping. OH MY GOSH it is the most annoying thing to not be able to grab some mail or do something quick without having to physically leave the key in the car or turn the damn thing off before stepping out of it. Does anyone know of a program that can silence that stupid beeping!?
  6. Elektroingenieur
    2,515
    3,253
    Three Touring
    As far as I know, even a Toyota Techstream diagnostic system can change only the settings listed in the Repair Manual (more info) topics linked from General: Introduction: Repair Instruction: Customize Parameters. I didn’t see any mention there of a setting to suppress the warning message or buzzer when the key is removed from the car with the hybrid system running.
    I realize you’re just stepping away briefly, but I imagine Toyota was concerned with the requirements of FMVSS No. 114, S5.1.3, for example, and with other scenarios having potentially serious consequences. Leaving the hybrid system on without a driver present might lead to a theft or rollaway, and if the car is left running in an enclosed space, there could be a risk of carbon monoxide poisoning. Driving a great distance without realizing that the key had been left far behind could also be more than a small inconvenience.
    krmcg likes this.
  7. Fadi1
    Fadi1 Junior Member
    62
    Jordan
    2018 Prius
    I used techstream from Toyota, and connect my laptop with mini VCI, techstream is really great to do such things, you could even run a live test for any ECU in your car
    2020XLEAWD likes this.
  8. Chas_B
    Chas_B Junior Member
    So Cal
    Hey krmcg, you still open to help? in Norwalk with a 2021 Prime XLE.
    Thanks in advance
  9. krmcg
    2,592
    2,388
    Whittier, CA
    Sure. I'm just around the block in Whittier.
    Chas_B likes this.
