Can Speedometer be adjusted
Discussion in 'Prime Main Forum (2017-2022)' started by Ridge Kennedy, Oct 19, 2020.
  1. orenji
    orenji Senior Member
    5,887
    3,488
    Drive 2 MPH slower and your issue is solved. ;)
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    But yesterday I encountered one of those temporary speed indicator devices that the city had set up, and it showed the same speed as the Prius's speedometer.
  3. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    And you can be certain that it was calibrated to 1/10 of a mile and re-calibrated often. :ROFLMAO:
  4. Mendel Leisk
    41,901
    When I look back-and-forrth between our (satellite nav) garmin and the speedo, there's typically one or two kmh discrepancy. This is on highway, going around 80 kmh (~50 mph)..
  5. Ridge Kennedy
    Ridge Kennedy Junior Member
    Thank you all for your informative replies.
    Sarge and Mendel Leisk like this.
  6. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I agree and can confirm this as well. I have the ScanGauge connected in my PiP all the time for extra gauges, and the dash speedo (and Waze, Google Maps, etc) all register a couple KM/h higher than the car does. As others have mentioned, I am sure it is for legal/liability issues, and I also agree that it may save oneself a speeding ticket one day. ;)
    Just don’t worry about it. (y)
