Engine cleaning service
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Rangerdavid, Oct 25, 2020.
  1. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I have a 2016 Prius 3 touring, it has about 50,000 miles on it. Our Toyota dealer is recommending an engine cleaning service that cleans the fuel injectors and cleans the engine. I'm wondering if this is worth the $200 that it cost to have done
  2. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    In my experience, 99% of “dealer recommended” services are scam. If it’s not in your factory maintenance schedule, it’s not needed. There is that 1% when something goes wrong, but that would be a recommended repair/service for a specific issue that needs to be resolved. Just say “no, thank you” and keep you cash.
    iPhone ?
    Rangerdavid, pjksr02 and krmcg like this.
  3. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Oh, and get a can of BG 44K and that’s your fuel system cleaner for the year.
    iPhone ?
    edthefox5 and pjksr02 like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Dealers love doing that - often it involves in "WRITING $200" on the invoice.
    TOYOTA have an Injector Cleaner - you add to the tank - we used it on Dad's CAMRY at 230,000km, and it did make a little difference.
    Rangerdavid and edthefox5 like this.
  5. bisco
    48,998
    'wallet cleaning service'
  6. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    Change the "lifetime" transmission fluid instead.
    edthefox5 likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    I like pj's post. Change that trans fluid with the $200- you just saved and it will look very bad but once you change it then it will be good for the life of the car. Its all the differential gear wear in there your getting rid of.
    pjksr02 likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Should you pay them $200 to do this........that you can and should do for yourself for about $10 ??
    Techron is available at any auto parts store and most farm supplys and many big box retailers (WalMart).
    I do mine once a year.
  9. alanclarkeau
    7,041
    7,580
    There's really no differential - though there are gears.
  10. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Correct it uses no pinion gear but there’s still a lot of wear where the final drive connects to the 2 cv halfshafts.
    I use the term differential for simplicity. I doubt there’s a lot of wear with the sun gear system but where the rubber meets the road much more wear initially.
    Changing my g2 trans fluid 3 times over 150,000 miles revealed high initial wear at 5000 miles with very little wear after that initial change,
    Pictures I have seen on this site of g3 fluid looked much worse which makes sense there much higher powered motors.
    But I still think just change it once at 5000 miles your good to go for the life of the car as it is a pretty prescision trans.
  11. Rangerdavid
    1,362
    52
    Three Touring
    Ok, so I'll just get a bottle of fuel injector cleaner and run through it. I'll also look into the transmission fluid change. I hadn't thought about that. Thanks!!
  12. ChapmanF
    15,111
    Prof. Kelly can be seen installing the differential starting at 10:24 in that video:
    Another view (from Art's Automotive, of a Gen 1):
    There'd be quite a lot of rubber left behind when turning corners if there were not one.
    alanclarkeau likes this.
