Help with P0420
Discussion in 'Gen 2 Prius Main Forum' started by Frontporch, Oct 26, 2020.
  1. Frontporch
    Frontporch Member
    398
    82
    Nj
    Hello,
    Was about to take my Prius for inspection in NJ after replacing the three way valve (sorry if that's not the name) that routes coolant. I had a check engine light on for over 6 months, but in NJ, you have to remove that even if not emissions related. Replaced the part, cleared the code... after driving a little while ... new code P0420. Darn.
    My Prius has 210K miles... I know that's a lot, but it is not an oil burner. Before doing anything drastic I would like to check some of the basics, like cleaning the MAF, verifying O2 sensor readings and anything else the forum members would suggest. I don't have a lot of diagnostic tools, but I do have a cell phone, an OBDII reader and the Torque app.
    So first off, probably everythings original in the exhaust. Cat failure at 210K common?
    Any suggestions going forward?
    My next plan is to clean the MAF and keep driving.
    Thanks!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    You can purchase a complete bolt in replacement on ebay for less than 400 dollars. I can put you in contact with a scrap dealer in texas that will buy your old cats for significantly more than that. You end up making money and have a new cat system.
  3. Frontporch
    Frontporch Member
    398
    82
    Nj
    That's interesting. I know the replacements don't have as much or the same catalyst. Kind of makes sense that maybe I don't need another 200K miles on a replacement. I have been burned by replacements. I put one in my Accord years ago that was a name brand and the CEL persisted. Could have been due to some other factor.
    I am going to keep your idea in mind and consider that if I can't get through inspection some other way. For now I sprayed the MAF sensor and am going to see if that helps.
    I did noticed on torque that there was only one O2 sensor reading. I should have two on a prius right? one forward and one rearward of the cat?
  4. Frontporch
    Frontporch Member
    398
    82
    Nj
    I am using the torque app that can show 8 o2 sensor readings. Only one, O2 1x2, has a reading. The reading for O2 1x1 is empty. Is that the upstream sensor? Also the OBDII monitor for O2 Sensor is marked as incomplete
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,462
    1,505
    NJ-USA
    I haven't tried Torque on a Prius so I don't know how it would display the upstream "oxygen" sensor (B1S1) .It's really an air-fuel sensor (or wide band oxygen sensor) and many "generic OBD2" scanners or apps don't handle it properly. Most Toyota compatible scantools display it as a voltage signal of around 3.3V - the voltage will vary with normal operation. It goes up when the mixture is lean, and down when rich. I usually see 3.2 to 3.4V at idle and 2.5 to 3.8 or so when driving.
    Other scantool might display the air fuel sensor as a milliAmp current value that reads somewhere between - 1.00 to +1.00 mA at idle with larger changes during hard accel or decel.
    If you have problems with the B1S1 reading then just look at fuel trims. Short term fuel trim varies with the B1S1 output but is typically near 0 +/- 2%. If it has to make a larger correction (away from zero) then long term fuel trim will make an adjustment to bring short term back. Short term plus long term equals total fuel trim. The few Prii I have seen have total trims of 5% or less. Anything within +/-10% wouldn't cause me concern.
    The B1S2 is a normal oxygen sensor so it will read 0 to 1V. Normally at a steady highway cruise with a good cat I see around 0.7V with minor flucuations.
    #5 mr_guy_mann, Oct 27, 2020
    Jonathan L likes this.
  6. dolj
    dolj Senior Member
    7,648
    3,860
    Wellington, New Zealand
    If you are using Torque and not Torque Pro, spend the $5 dollars and get Torque Pro. Then install the Prius specific PIDs that come with Torque Pro. See what you see then.
  7. Frontporch
    Frontporch Member
    398
    82
    Nj
    Thanks for that advice. I have an older copy of Pro on a tablet. Going to connect that and measure O2 and fuel trims and post those here.
  8. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    Keep in mind, your Gen 2 catalytic converters are a target. It's not 'if you get hit', it's 'when you get hit'. We're starting to see thefts in the southeast now. In NJ, you're on borowed time. Your choices are to either wait until it's stolen and then eat a big repair bill, or change it yourself and you get to make the money on the deal instead of a thief. With an aftermarket cat, your car will be left alone.
  9. Frontporch
    Frontporch Member
    398
    82
    Nj
    I took a drive with Torque Pro and the O2 sensors appeared to be in the ranges mentioned, with one small exception. The front sensor looked like it snapped to 5.0v on release of the throttle, and then went back to normal values.
    I did notice that the final O2 sensor monitor completed and the check engine light disappeared. I was able to take it to inspection where it passed. two more years to not have to worry. Fuel economy is reasonable 45-48 but not incredible. battery voltages appears to be even across all the cells... seem to max out around 17+ V.
    I would like to know more about the catalytic converter issues. Is there something special about the Prius compared to other vehicles or is any car or truck in the last 30 years with factory exhaust a candidate for theft. I have a 99 Ford ranger with California emissions and that would be a lot easier to get under.
    I have also noticed there is a manufacturer that sells metal plates to cover your exhaust and keep thieves away. I wonder what the NJ inspection with their cameras under the vehicle would think about those.
    Thanks
  10. mr_guy_mann
    3,462
    1,505
    NJ-USA
    5.0V for the B1S1 on decel is normal. I said before that voltage goes up when the engine is lean. I forgot to mention that on decel the ecm cuts fuel completely, so the sensor goes to its maximum lean range.
    The OE Prius cat has fairly high amounts of precious metals in order to meet PZEV emissions standards-- even though the engine isn't running all the time. The price of platinum and palladium are way up recently. And the the cat on a Prius can be cut off in a minute or two. So the Prius is a target.
    I looked at one of those security shields for my car and supposedly it has a strategically placed cutout so that visual inspections can be done.
  11. Leadfoot J. McCoalroller
    7,165
    6,714
    Pennsylvania
    2018 Prius c
    It's relatively big, and has a lot of the money metals in it compared to anything else on the street. Way better payday-per-attack than any other car.
    Why risk jacking 7 Rangers when you can do one old Prius? Less to haul in the getaway car, they can go back to their villainous lair earlier and spend even more time planning smaller candy sizes for next Halloween.
  12. Frontporch
    Frontporch Member
    398
    82
    Nj
    Well... you called it. I parked my car in a Extended Stay America hotel in Elizabeth NJ and went on an extended vacation. When I got back, my cat was stolen. The car was parked in a fenced lot, but what does that really mean? I filed a police and incident report, but not sure anything will come of it.
    Also, the cuts they made were beyond the flanges on both sides of the Cat. This means both the exhaust header and the exhaust pipe behind the Cat were damaged.
  13. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    This has to be the absolute worst of the worst possibilities. Very sorry to hear that.
  14. Frontporch
    Frontporch Member
    398
    82
    Nj
    OK.. I am an idiot. I looked at the factory part and it runs from the exhaust manifold flange all the way to near the back axle and includes the catalytic converter, oxygen sensor and silencer.
    The cut on my exhaust was after the oxygen sensor and between the second cat and the silencer. In other words, half my cat was stolen and I still have the oxygen sensor. Maybe that's why I didn't get a check engine light while driving.
    Toyota's estimate to fix this... $2700, but an aftermarket unit and a gasket might get the job done.
    There must be some value to the first cat and if you still have your contact, I may be able to get some $$ back for that part.
    Thanks.
    #14 Frontporch, Jul 1, 2021
  15. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    You have officially found the second most stupid thief on earth. He stole the cat that was worth the least. The great news is you can now remove the O2 sensor, detach the remaining CAT and install an aftermarket replacement without having to buy a new O2 sensor. The upper cat will more than pay for your new aftermarket assembly.
    The #1 dumb crook was the guy who cut the aftermarket cats out of my sons car and made his lower cut right next to the big 'ol U-bolt that was sealing the pipes together.
  16. Frontporch
    Frontporch Member
    398
    82
    Nj
    What makes me happy is that the thief didn't get all of the prize. Bastard. The street value for an aftermarket must be pocket change, but I guess once you are under there, you just remove it anyway. I guess I have to consider putting in a plate of some sort. Maybe do the equivalent of an electric fence wire.
    If you have time....
    Can you provide me the contact info for the cat buyer in TX you had mentioned in an earlier thread?
    What aftermarket did you go with and has it been keeping the CEL off?
    For aftermarket I see some starting at $150 that fit over the old exhaust pipe to ones that are name brand for $300 or more
    Thanks.
  17. Frontporch
    Frontporch Member
    398
    82
    Nj
    Thanks TMR-JWAP for your help.
    For anyone reading, it helps to understand the motivation for people to steal these converters. At the current price of scrap metals, the converters have a scrap value well over $1000. Aftermarket replacements do not have the need to meet the original high standards that Toyota's parts did (except for California). Aftermarket units will meet the emissions standards of most states and can be purchased for $150-300.
    Stealing a Prius catalytic converter is a relatively easy task. It doesn't take a competent thief much more than a few minutes to raise your car and remove the exhaust.
    On a side note, if you get your catalytic converter replaced because you suspect its not getting the job done, you also have the right to ask for and recycle your old OEM part... otherwise your mechanic will do it :D
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Going on eBay for $1500-1600 maybe more.
    Lookup G2 Prius on eBay. People in carb states are desperate as the oem is back ordered,
  19. Andy Ting
    Andy Ting Junior Member
    Boulder, CO
    Got the same problem with O2 1x1 as well...even with the paid torque pro app.
    My O2 1x1 is constantly at 0.1 and O2 1x2 is fluctuating from 0.1 to 0.9. (My vehicle is gen2 Prius)
    Does anyone have the idea about the reading?
    Thanks.
  20. Frontporch
    Frontporch Member
    398
    82
    Nj
    I can’t say what my normal O2 readings are without putting in the OBDII tool but I can say my check engine may very well have been from an exhaust leak from deteriorated gasket between the exhaust manifold and catalytic converter. It was original with 200k+ miles
    The cel has been off since the gasket was replaced. The catalyst monitor was pretty quick to be satisfied with one or two short trips. Trip required exhaust to reach normal operating temperature.
    Do you have a CEL?
