Worried! Please help!
Discussion in 'Gen 2 Prius Main Forum' started by Yeetle, Oct 20, 2020.
  1. PriusCamper
    PriusCamper Senior Member
    10,926
    4,430
    Pacific Northwest, USA
    Always great to read of someone who's clearly competent and know what they're doing... Keep up the good work! As for MPG, it's hard to get accurate numbers until after 50 miles or so...
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,253
    1,359
    NJ-USA
    If you want to replace modules on your old HV pack then you should perform discharge and charge cycles on all the modules to determine and "equalize" capacity. Either do it all at once with a grid charger like the Prolong system (more money, less time), or piecemeal with hobby chargers (more time and effort, but less money).
    Just replacing some modules on a battery pack as a high risk of throwing more codes as modules in different condition (capacity and state of charge) will have different voltage levels under stress.
  3. PriusCamper
    10,926
    4,430
    Exactly!!!
