EGR Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Oct 31, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,221
    929
    So I have been thinking about doing this and opened her up today to have a look.
    Once I did that I could clearly see that this needs to be done, I would say for anyone to clean the pipe every year.
    I will see if I buy one from junk yard and clean it or find a new one on the cheap.
    When I used my flashlight, there was no light passing through the pipe.
    Im positive that the rest of the egr is just as clogged.
    Just trying to get the best out of the car and will be getting a new upstream a/f sensor because Im sure it is original. 20201031_112002.jpeg 20201031_112037.jpeg 20201031_112133.jpeg 20201031_112157.jpeg
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    " I would say for anyone to clean the pipe every year."
    The EGR pipe is just the tip of the iceberg (so to speak...). The entire EGR circuit must be cleaned. If that pipe is cruddy, the cooler is probably worse...
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Based on the pics, the whole circuit will be packed:eek:.
    Be prepared for the whole circuit to require the cleanse;).
    Pressure washer works good for the cooler and will save having to buy a spare :).
    Good luck and keep us posted(y).
    Grit, m.wynn and pjksr02 like this.
  4. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    How many miles on the patient?
    Raytheeagle likes this.
  5. AzusaPrius
    2,221
    929
    She has just over 180k
    Everyone should clean this by 100k
    What happens is the exhaust just backs up with pressure and continues to heat the coolant up which causes the engine to overheat and work harder.
    This is all meant to heat the engine up quicker to save gas but as it glogs it continues and causes misfires with cold starts.
    #5 AzusaPrius, Nov 3, 2020
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    My understanding of the necessity of an EGR circuit is a bit different. It is a method for controlling the temperature of combustion in each of the cylinders by the metered introduction of exhaust gas. Any inert gas could be used for this, because all it does is displace oxygen in the induction charge. Exhaust gas is readily available and already pressurized, but it contains soot from unburned hydrocarbons which build up in the passageways and slowly reduce the efficiency of the process resulting in higher combustion temperatures and eventual failure of the head gasket. Just a side note, and I don't want to say this too loud as my Prius might be listening. I have 245K on my 2011, 98% highway miles, and I have not checked my EGR at all. I am getting ready to trade in though, as that kind of mileage brings other worries.
    mjoo and Ed Beaty like this.
  7. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    not really....
    "In internal combustion engines, exhaust gas recirculation (EGR) is a nitrogen oxide (NO
    x
    ) emissions reduction technique used in petrol/gasoline and diesel engines. EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. This dilutes the O2 in the incoming air stream and provides gases inert to combustion to act as absorbents of combustion heat to reduce peak in-cylinder temperatures. NOx is produced in high temperature mixtures of atmospheric nitrogen and oxygen that occur in the combustion cylinder, and this usually occurs at cylinder peak pressure. Another primary benefit of external EGR valves on a spark ignition engine is an increase in efficiency, as charge dilution allows a larger throttle position and reduces associated pumping losses.
    In a gasoline engine, this inert exhaust displaces some amount of combustible charge in the cylinder, effectively reducing the quantity of charge available for combustion without affecting the air-fuel ratio. In a diesel engine, the exhaust gas replaces some of the excess oxygen in the pre-combustion mixture.[1] Because NOx forms primarily when a mixture of nitrogen and oxygen is subjected to high temperature, the lower combustion chamber temperatures caused by EGR reduces the amount of NOx the combustion generates. Gases re-introduced from EGR systems will also contain near equilibrium concentrations of NOx and CO; the small fraction initially within the combustion chamber inhibits the total net production of these and other pollutants when sampled on a time average. Chemical properties of different fuels limit how much EGR may be used. For example methanol is more tolerant to EGR than gasoline.[2]"
    Raytheeagle, Ed Beaty and AzWxGuy like this.
  8. AzusaPrius
    2,221
    929
    In the prius.....the egr is to speed up the warm up cycle to save fuel.
    pjksr02 likes this.
  9. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Below is pretty key for Prius. If you monitor EGR valve position you'll notice it considerably open at highway speeds and moderate to heavy acceleration. It tapers some if you stomp on the gas pedal but cruising at 70 and then starting to climb a slight grade the engine relies heavily on EGR.
  10. ChapmanF
    18,457
    In the Prius.....the egr is to reduce NOx formation and increase engine efficiency through reduction of pumping losses. As it is in other gasoline-engine cars.
    Gen 3 Prius also has an exhaust-heat recovery system. It's way further down the exhaust. Coolant hoses flow to it and back. Not any part of the EGR. Probably what AzusaPrius is thinking of with the "speed up the warm up cycle" business.
    #10 ChapmanF, Nov 4, 2020
  11. Tekken
    Tekken Member
    259
    77
    Los Angeles, California
    I cleared my 2013 @ 97K. The Pipe didn't look that bad, but the EGR Cooler look worst than your pipe.
    Raytheeagle and Grit like this.
