HELP! What's this tire mark MEAN?!?!
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Oct 25, 2020.
  1. Mendel Leisk
    38,219
    24" breaker bar helps with lug nut removal. Were those lug nuts installed by "pros"? That would explain the need to stand on the wrench.
    I'd second a floor/style bicycle pump; that's all I ever use now, even for a near completely deflated tire, say after a plug repair.
    Tire marks in my experience are always indicating what corner the wheel came off of. It's the only sensible way to mark them.
    cyberpriusII and fuzzy1 like this.
  2. fuzzy1
    10,039
    ... very frequently discounted at Harbor Freight, though just about any stray section of iron pipe, large enough to fit over the lug wrench handle, is sufficient.
    cyberpriusII and Mendel Leisk like this.
  3. Prius Maximus
    Prius Maximus Senior Member
    930
    775
    Northeastern IL
    I'm too lazy (old, decrepit?) to use a breaker bar anymore. cordless impact wrench is the way to go... but it does cost a few extra bucks
  4. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    For auto and motorcycle work, I've never ever had an issue with using PVC tubing; much lighter, cheaper, and doesn't rattle in the trunk. It's more than strong enough to snap a lug right off. My "nuclear option" is a 6 foot long piece of 3 inch oil field pipe. ;)
    fuzzy1 and cyberpriusII like this.
  5. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,135
    1,560
    Iowa
    O.K. I guess I am a little girl who still worships her father.
    But, I also forgot that he taught me what he called the "gorilla" trick with the pipe extension, oh, so long ago.
    And, in my first car, I NOW remember I did carry a piece of pipe that fit over the "tire wrench."
    So, I have no one to blame for my extremely sore hip and leg than myself.
    but, the idea of a PVC extension is extremely appealing. Light, cheap and "workable." What diameter and what length for the "normal" passenger car are we talking about?
    I am also toying with the idea of buying the $50 Harbor Freight Impact wrench, though I probably will not. I want to get back to rotating my own tires (yes, insane, but I enjoy it --maybe).
    kris
    #25 cyberpriusII, Oct 27, 2020
  6. Mendel Leisk
    38,219
    Corded electric impacts seem to be going the way of the dodo. Sadly? They seem cheaper to buy, no bulky battery and a charger. Maybe they can't match the torque of the battery powered??
  7. cyberpriusII
    1,135
    1,560
    Iowa
  8. fuzzy1
    10,039
    I'll have to give it a try, with the upcoming winter tire swap. It would certainly lighten the load in the trunk.
    And would be a good addition to the smaller niece's vehicle tool kit. When her hand-me-down Explorer had a flat, she could do almost all of the tire change herself, except that she just didn't have the body weight to break loose the lug nuts with the regular wrench.
    cyberpriusII likes this.
  9. ChapmanF
    15,078
    I have a section of stout PVC here, 1½" or so, that I used a few times for some breaker action. It is shorter now than it was when I conscripted it for that job, and one end of it is very jagged and sharp, and my recollection is that shards of it went flying far and fast.
  10. fuzzy1
    10,039
    ^^ Any recollection what schedule it is/was, 40 or 80? White or dark?
    And what size vehicle was it used on? That Explorer will need something more stout than my Prius.
  11. Mendel Leisk
    38,219
    I'd get a breaker bar; they're cheap. 1/2" drive by 24" maybe?
    Taking a regular handle ratchet wrench and extending it with a pipe is likely overtaxing it's mechanism, could break it.
    Ok I guess a "cheater" would be ok to extend the Toyota lug wrench, say left in the car. I'd be inclined to use a steel plumbing/gas pipe. You could tape it to reduce rattles.
  12. cyberpriusII
    1,135
    1,560
    Iowa
    I still have not seen a recommendation in terms of size and schedule. I think I will go with 1" schedule 80. Maybe 18-inches.
  13. ChapmanF
    15,078
    This might be a place to mention two things I routinely do:
    (1) I use a torque wrench, and 76 foot-pounds, when I put the lug nuts on.
    (2) I have a little jar of anti-seize. I never put it anywhere, except a little dab now and then (from the tip of a jeweler's screwdriver) in the little gap between the captive washer attached to the lug nut and the bottom of the lug nut itself, where it bears down on the washer. And I spin the washer back and forth a bit so that little dab is spread around on the bottom of the nut.
    When I go to take the lug nuts off, it just isn't ever an uncivilized experience in the least.
  14. cyberpriusII
    1,135
    1,560
    Iowa
    Well, I spent another bit of cash on a Slime tire pump :cry::cry::cry:. Hmm....
    I found the Slime Garage kit on EBay, made a bid and $38.80 later....The kit seems pretty good. Retails for around $85 USD.
    Only issue is that it "screws onto" valves. Prefer the "press and clamp system." Buying an $8 extension hose solved that issue. It has fairly long reach,seems solid. Kit includes tire depth gauge. Works well so far. Time will tell.
    120V Garage Tire Inflator with Accessories Kit | Slime – Slime Products
    kris
  15. LesGas
    LesGas Junior Member
    Lyndhurst, Va.
  16. fotomoto
    5,597
    3,771
    So. Texas
    Here's the collection of cheater pipes I use with breaker bars. I manage to bend one of the smaller ones on an FWD axle nut; moved up the 1&1/4 inch PVC + "nuclear option" (6ft metal pipe) which popped it loose quite easily. I have similar ones to the middle pipe in the picture stored in every car with a breaker bar+correct socket size. Just like in use, I store the breaker bar inside the pipe so no rattles.
    Prodigyplace likes this.
  17. LesGas
    Lyndhurst, Va.
    might want to consider picking up a 13/16” impact socket to go with and keep it handy in the vehicle should you need it. That’s what I use.
