2010 Prius V with 144k miles. Should I buy?
Discussion in 'Gen 3 Prius Main Forum' started by Dresden196, Nov 9, 2020.
  1. Dresden196
    Dresden196 New Member
    New York
    I found a gen3 2010 Prius V in my area with 144k miles for $5,900. Looks to be in excellent condition and It has every option possible including the rare package with lane keep assist, adaptive cruise, and, self park. Also has leather heated seats, and navigation. Battery shows as replaced on carfax around 70k miles, which I thought was quite early for a replacement, but other then that it has brand new tires, ball joints, and suspension. My budget is $8,000, should i go for it or keep searching for like a gen4?
  2. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Which battery was replaced at 70K? The 12 volt battery for $300, or the traction battery for $4000?
    Do you do your own maintenance? If not, I think it's a bad bet.
  3. bettergolf
    bettergolf Active Member
    493
    370
    Sanford NC
    Hybrid battery is not $4000. With gas where it is I don't see why anyone would buy a Prius with over 100k with all the expensive repairs that could possibly be needed in the future. The money you'll save on gas just doesn't add up to those costs.
    Also I don't think you'll find a Gen4 for $10000....I've been looking.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There’s a sub forum area called Prius V, post there & you’ll have more replies.
  5. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Going by the averages (10 years old with 140K) it was replaced 5 years ago. $4K is about what dealers were charging at that time. Some are still charging that.
    I agree 100%.
  6. Mendel Leisk
    42,271
    Not sure, 2010 (and maybe 2011?) Prius hatchback had a level "V", in the US.
    Come to think of it, Prius v (lower case) started in 2012.
  7. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    Depends on where you live. Some places have high gas prices. In Canada even though gas prices have been a bit lower than normal they are consistently above 4$ per gallon (1.10-1.35 per litre), and have been for the past decade. Really makes sense to have a fuel efficient vehicle at that price. I imagine some parts of the USA also have consistently higher gas prices (California).
  8. Mendel Leisk
    42,271
    Currently back up to $1.50 CDN per liter, on the west coast. :(
  9. tonycd
    tonycd Member
    84
    56
    I'd do it in a heartbeat. I have a 2010 Prius V with almost exactly this mileage. I got it at 94k miles and caught up on all the routine service. It uses a modest, unobjectionable amount of oil. The grand total of failures since I got it: A passenger-seat sensor wire I carelessly knocked loose with some underseat cargo, some corrosion on the lips of the alloy wheels that had to be sanded off to stop a slow leak, a $10 overhead map light lens, and three minor exterior light bulbs.
    The Five remedies all the complaints that one sees most about the lower models: unentertaining steering, seats with poor long-haul back support, mediocre headlights, and a crappy stereo. I don't have the rare-as-hen's-teeth package your candidate car has, and I wish I did—it's said to work well. The battery that was replaced on that car was almost certainly the small one, which regularly gets replaced after 7 years and is no cause for alarm.
    I don't understand the fatalism that often pervades this board. The Prius, while a machine and therefore not immortal or perfect, is statistically pretty much THE most reliable car one could buy. That price is appropriate, the car is rare and special, and I'd be all over it like white on rice.
    ASRDogman likes this.
