Heating Controls on steering wheel not working
Discussion in 'Gen 3 Prius Technical Discussion' started by Ash Patel, Nov 16, 2020.
  1. Ash Patel
    Ash Patel Junior Member
    Bolton
    I have a 2011 Toyota Prius T-Spirit and just realised the temp up and down buttons don't work. When I press the button on the steering wheel it shows on the display that I am pressing it but the actual temperature doesn't go up / down. It works fine if I do it from the button on the main display by just doesn't seem to work on the steering wheel even though it shows on the display the button is being pressed. Any ideas?
  2. Attila Fekete
    Attila Fekete Member
    164
    58
    Budapest, Hungary
    Do you have issue with any other button on the steering wheel?
    What you see on the display is from a proximity sensor/ECU, so doesn’t mean it recognised that you pressed that button.
    I think it may be the spiral cable.
  3. Ash Patel
    Bolton
    No its just with the temp up and down button. All other buttons are fine.
