help!! BUYING AN 80K PRIUS HYBRIDE BATTERY DEAD OR 12V?? AFTER TEST DRIVE
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius91, Nov 21, 2020.
  1. prius91
    prius91 New Member
    amsterdam
    Business Edition
    hi guys,
    Today I went in my mini cooper S to a big garage seller. And i wanted to trade my red mini cooper s r53 in for an zilver 06 prius with low miles. ( the mini likes fuel....)
    The test drive went wel, drove good also on ev mode very wel no problems etc... until... i decided to park the car on the side of the road and turn it of just to inspect the car more also look under the car.
    After I was done, i wanted to start te car, but the parking brake button stayed on and the start button went orange and light where lighting on the schreen. it did not wanted to move at al. also i depresed foot brake and pressed nothing stil parking brake light and no move...
    I also noticed that the battery bars on the screen where all gone... and the car did not wanted to start nothing...
    What can this be de 12v battery? before no triangle of death or lights etc
  2. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
  3. rjparker
    10,473
    6,567
    Did you buy the car? If not, then let them worry about it. It is possible that the 12v battery is discharged or dead, that would be the easiest to check and fix. First try a jumpstart. Second load check the battery. Otherwise, it could be more significant.
  4. prius91
    prius91 New Member
    amsterdam
    Business Edition
    HI at the test drive i called them to come with an battery pack and in the meantime i was fiddling with the car button etc etc and then it jumpt back to life with the 3 bars on the screen before I stopped.
    Before when i wanted to start the car the battery bar on screen was 1 or 0 battery bars., Maybe aux battery?
  5. prius91
    prius91 New Member
    amsterdam
    Business Edition
    Almost casue I drove the car beforhand and it drove verry good also on Ev mode... only when I turnt the car of and wanted to start nothing.. they offerd me to pay them 5100 dollar with the mini cooper s 2006 the mini has rear damage, rack in window front and paint faiding sports etc etc
    so an good deal ? maybe i wil try to buy it and buy an new 12v battery maybe that helps... its a risk... the car only has like 86000 Miles genuine miles.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    If you don't know what the fault is, why make it your problem? Unless you are comfortable diagnosing and repairing cars then you might want to pass on this one. Maybe it could be just a bad 12V battery, but it could be more.
  7. bisco
    52,360
    welcome!
    it's probably the 12v, but even so, a 2006 will need a new hybrid battery sooner than later. it's age more than miles.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Generally speaking, driving around in EV mode isn't a great idea, it will only help the HV battery fail sooner, rather than later.
    Did you fully deplete the stored charge (there isn't much) in the HV battery, without a charged HV battery you can't start the vehicle.
    jerrymildred likes this.
  9. PriusCamper
    13,021
    5,291
    But it's a great way to torture test a battery pack before you decide to buy it or not... :)
  10. rjparker
    10,473
    6,567
    I would have the seller replace the 12v battery and offer some sort of comprehensive warranty, ideally for six months to a year. This is a 15 year old car and the high voltage battery, if original, is not likely to last long. Over here it would cost around $2000 usd to replace it. This is not really an EV car (maybe 1 mile range) but the high voltage battery must function or it won't run. Here $5100 usd would be ok if everything was excellent. If its $5100 nlg ($2745 usd), that would be a very low price which would cause concern about possible problems.
    But the silver gen2s are nice. Mine back in the day:
    #10 rjparker, Nov 21, 2020
  11. prius91
    prius91 New Member
    amsterdam
    Business Edition
    hi i converted the euro nl money and mileks kms to miles in my topic so the 5100 is converted euro nl money
  12. PriusHead05
    PriusHead05 Member
    318
    The Gen 2s don't have an all EV mode that you can put them in manually. That came in the Gen 3s.
  13. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Different markets were offered different options.
  14. prius91
    prius91 New Member
    amsterdam
    Business Edition
    this one i drove it had an EV Button.. Also automatic parking button it can park automatic
  15. PriusHead05
    PriusHead05 Member
    318
    Are you in Europe? I was talking about the US models.
  16. prius91
    prius91 New Member
    amsterdam
    Business Edition
    ooh yeah im in the nederlands!
  17. PriusCamper
    13,021
    5,291
    Toyota took the EV mode out of Gen2 in US models because of 10year 150K mile warranty on hybrid battery in many US states. The ability to do that still exists in the car and you can wire it back in: https://www.coastaletech.com/electric_only_mode.htm
  18. PriusHead05
    PriusHead05 Member
    318
    Thanks for that info! I was wondering if there was a way that could be done.
  19. rjparker
    10,473
    6,567
    I would not spend the money on the ev button since it barely works at very low speeds for maybe a mile if you are lucky. Plus the car will start the engine when cold.
    PriusHead05 likes this.
  20. PriusCamper
    13,021
    5,291
    I agree entirely with regular NiMH packs... Draining the battery down in less than a 1/2 mile is a huge waste of energy that the gas engine has to replace.
    HOWEVER
    Currently testing a pre-production Dr. Prius Lithium pack in my Gen2 and I can go more than 2 miles without pack going below 4 bars and it re-charges at 96% efficiently compared to NiMH's 70% efficiency.
    I never thought I'd ever use the EV switch, but in order to torture this test pack that's what I've been doing and so far it's not acted tortured.
