What tips do you have for storing a Prius for 3 months?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin_Denver, Feb 4, 2017.
Tags:
  1. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    In a week, I'm leaving to travel Thailand and SE Asia for 3 months. In a more ideal world, I would be able to store the car in a garage or have a friend drive the car every few weeks, but it looks like my only option is to store the car outside with no option for a 12V battery maintainer.
    My plans for the car include doing the following just prior to storage:
    1. Inflate tires to maximum sidewall or a little bit higher to help prevent flat spots from forming
    2. Force charge hybrid battery to "full" (8 bars)
    3. Wash the car and underbelly to get the salt off the car from the winter to keep rust from forming
    4. Disconnect 12V battery
    5. Leave the car with less than 1/2 tank of gas
    Upon returning I will:
    1. Reconnect 12V battery
    2. Check and inflate tires appropriately
    3. Drive the car on its first start to a gas station and add new gas
    4. Change the oil within a few days
    Is there anything I'm missing? What additional things would help maintain the car? Do I need fuel stabilizer, or should I be okay for 3 months?
    52,386
    i think you're good. any mouse proofing necessary?
    Mycaleum likes this.
  3. Patrick Wong
    18,210
    6,513
    Regarding #2 of the items to be performed prior to storage, it is more important to make sure the 12V battery is fully charged before storage, especially in freezing weather. I would be less concerned about the traction battery as long as it is sitting at 6 bars or better.
    Regarding #4 of the items to be performed prior to storage, I suggest you effect the disconnection by unbolting the cable that connects to the positive jumpstart terminal.
    Remove the cover on the main relay/fuse box. Open the red cover over the dedicated jumpstart terminal. Find the nut which secures the cable to the stud.
    You need a 10 mm socket to remove the nut. Then pull up on the cable to remove it from the stud, thread the nut back on the stud, close the red plastic cover, then lay the cable on top of the red plastic. Finally, replace the cover on the main relay/fuse box and close the hood. By doing all of that, you don't have to crawl into the hatch when you return to the car.
    Regarding #5, I personally would fill the tank fully to reduce the space available for water to condense within the bladder. However, since the bladder shrinks down as the fuel level drops, you could go either way.
    Regarding #2 of the items to perform upon return, I routinely use 44 psi/42 psi for normal driving, hence I would not deflate the tires upon return.
    Regarding #4 of the items to perform upon return, I personally would change the engine oil and oil filter prior to storing the car. If the oil is in bad shape, how does it help the engine to have contaminated oil and water condensation within the crankcase for three months?
  4. bisco
    52,386
    i've been wondering about that patrick, i change my oil every spring. would late fall be better? car sits for 5 weeks in feb/mar, but then, the engine is off a lot all winter.
  5. Patrick Wong
    18,210
    6,513
    In your case I suggest changing the oil in late January, or immediately prior to the longest storage period. The oil should be changed at least annually if you log low miles.
  6. Kevin_Denver
    581
    425
    Denver, CO
    Great tips! I'll get my oil changed this week, and I like your advice about disconnecting the battery at the jump point instead of in the trunk. The maximum sidewall pressure on my tires is 51psi, so I was thinking of storing the car with them at 60 or 70, and then deflating back to my usual 45 upon return. Perhaps the best for gas would be to store it at 3/4 tank and then top off ~2 gallons of premium when I return (as gas drops in octane as it ages)?
  7. Kevin_Denver
    581
    425
    Denver, CO
    Denver doesn't have bad mice problems as the winter is cold enough to kill most all of the house mice living outdoors. However, I never say never. Are there some easy ways to guard against mice? traps?
  8. bisco
    52,386
    there are quite a few mouse threads here. the problem with traps when you're away is, who's going to empty them. i suppose poison inside and out might help. moth balls, peppermint? but maybe not an issue. we have tons of field mice, and the only thing the cold does is make them try to find a way inside.
  9. Mendel Leisk
    41,898
    I'd stick with max sidewall. I think that's how they come from factory, fwiw.
    Patrick Wong likes this.
  10. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    And be sure the last time you drive it, you put it away fully warmed up, to reduce condensation in the engine.
  11. bisco
    52,386
    i pump my tyres to the max sidewall for the 5 or 6 weeks i'm away, then drop them to 42/40 when i get home. and i still get a bit of a flat spot for awhile.
  12. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    If the maximum recommended pressure is 51 PSI, why are you contemplating 60 or 70 PSI? It seems you have a differing definition of maximum to me.
  13. Kevin_Denver
    581
    425
    Denver, CO
    51 psi is the maximum pressure the tire is rated for during use, all the way up to its maximum speed (130mph). Consider the difference in stress on the tires when merely sitting and supporting the car versus dashing down a road at 130mph. The burst pressure on most tires is about 200 psi. As the tires will only be stored at the higher pressure and not driven, I can push the limit a bit. Back in my hypermileing days, I would run the tires at 20 or 25% above maximum sidewall, with no ill effects on the tires (handling, noise, fuel economy, etc. were obviously affected).
  14. JessO
    JessO Junior Member
    QuadCities
    I was working on my Prius, disconnected the 12V batter, then shut the hatchback. To reconnect it, I had to use the mechanical key on the driver's door, then unlock the passenger door, then remove kid car seats, fold down the rear back and crawl into the trunk to reconnect the 12V. If you are disconnecting at the engine, good luck, but if you need access to the 12V itself, leave a path.
    For storing your gas that long you can get fuel stabilizers, I like Seafoam, but many can help.
    Also, I have a car cover for my Prius, (usually for snow) but the generic "any car cover" can be cheap. Good luck with storage and enjoy Thailand!
  15. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    when you get home, let the car warm up 5-minutes and check state of charge on HV batt. What happens if you just pull out and drive after sitting sometimes the HV Batt goes into the purple real fast.
    Gaso does not really lose much octane on sitting as far as I know. Using mid grade would correct for that. Stabil would be good but also maybe I would consider E0 if available. E0 not available by me, so sometimes my lawn mower experiences separation of ethanol/water mix.
  16. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes. FILL the gas tank and don't worry about the hybrid battery as long as it is "mid-range" in it's charge.
    Stabilizer probably not required but a good idea anyway.
    And.....IF you still have the original OEM 12 V battery in the car, it is about time to replace it anyway and when you get back from your trip would be a good time to do that.
  17. waldox
    waldox Junior Member
    69
    toronto
    long term storage tips from toyota tech on hybrid storage
  18. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    I believe toyota says to pull the orange safety plug on the traction battery if you will not be using the car for a while.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Before going to the airport remove the hatch cover and remove the plastic basket that covers the spare tire. Leave them at home. Drop the rear seats down and remove anything in the back.
    Way before the trip Spray some lube in the drivers side keyhole. Remove the metal key from the fob and make sure your key works. If you have not opened that door with the key before spray lube in the hole then rock the key gently back and forth till it Free's up and easily opens the door.
    It will probably be freezing when you return. I hate WD40 but its perfect for this as its more kerosene then lube.
    Then at the airport remove the two12 volt plugs from the 12 volt battery there easy they just unplug by pressing there lock tabs then remove the 12 volt battery back up black box connector which sits right next to the 12 volt battery and if all 3 of those are unplugged the entire 12 volt circuit is disconnected from the car then remove the orange safety switch for the hybrid battery. When these 4 plugs are removed the 12 volt is completely disconnected and so is the hybrid battery. No tools required. NOTE: in order to get to those 12 volt plugs you have to pop off the plastic red cover on the battery. Mines been off for 13 years lol.
    Here's why I asked you to remove the hatch cover and leave it at home:
    When you return you can easily open the front door with the key and then lay in the back and plug in all 3 wires for the 12 volt circuit then plug in the orange safety switch. Takes like 25 seconds and I'm 65 years old. Its really easy and quick and foolproof. This is actually much easier then trying to open the hatch with the 12 volt dead. That sucks.
    It may be dark when you come home leave a flashlight in the hatch hole.
    I just did it today I needed some welding done on my g2 today. Never have to open the back hatch.
    No tools no wrenching required Toyota has given you all the disconnects you need to disconnect all power to the car.
    My way takes literally 30 seconds to restore.
    PS: If your 12 volt battery is older then 2 years old you may want to buy a jump pack and leave it in the car just in case.
    #19 edthefox5, Nov 27, 2020
  20. rjparker
    10,503
    6,593
    As noted in the video above, get a comprehensive car cover. Be careful about disconnecting and reconnecting the fuse box 12v cable, you could have a bad day if it shorted with the 12v battery still attached. You will also end up with a hot lead dangling. There is a big specialized fuse in the batteries positive terminal that would easily blow and might be hard to get on the spur of the moment.
    Personally I would leave a lithium jump pack in the car and disconnect the battery ground. Then use the jump pack to power up the system when you return. Plus if the 12v battery was marginal you might need the jump pack anyway.
    The hv battery does not need anything since it is already disconnected by internal contactors on every shutdown.
    I would change the oil the day before and again soon after your return. Use the cheap oil before and return to normal on return. The filter could remain in the second time.
    Be aware the system may not go to Ready on the first attempt after connection of the 12v battery. Just try again once or twice.
    edthefox5 likes this.
