Where to split into gas system
Discussion in 'Prime Accessories and Modifications' started by Mikhail Bond, Nov 16, 2020.
  1. Mendel Leisk
    41,408
    Isn't the Ford Fusion there? :whistle:
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    What ??
    Where ???
  3. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I tried that, turns out it takes a lot of practice, the drogue can really scratch up your grill before you get good at it.
    jerrymildred, Hicksite and Bob Comer like this.
  4. kenmce
    1,544
    515
    NY
    Mikhail, People here are nervous about the thought of carrying around a big lightly secured can of explosive liquid. I can understand that. The proper way to do it would be to find someplace on the underside of the vehicle to add a second tank, plumb it in securely. I don't know if you could borrow pressure from the first tank to pressurize the second. I don't know if such a space exists or not on your car. The only other place that come to mind is to build a tank into the bottom of the trunk. You would still have the question of how to seal it off from the interior of the car.
  5. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    It was more of an idea, at the end of the day.
    I opted for the roof cargo and a extra gallon of gas in case I need it.
    Just finished a trip and averaged 35mpg. So you can see where my 10 gallons of gas gets me.
  6. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    35 mpg? Were you driving in charge mode?
  7. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    No, haha.
    I had a sportrack cargo carrier. See pic
    I've since switched to a Thule and I'm getting about 40-45.
    I had a full car, two dogs, and a full cargo carrier.
  8. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
  9. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    I see, thanks!
  10. Leadfoot J. McCoalroller
    8,076
    7,557
    Pennsylvania
    2018 Prius c
    Good numbers for heavy-hauling in a Prius. Nice pictures, thanks!
  11. Xeno
    Xeno Junior Member
    25
    17
    Anyone else having memories of the Pinto?
    MTN likes this.
  12. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    Friend had a pinto, I had a maverick. I do remember something about a corsair.
    The son of the owner of the body shop I worked at put a corsair engine in a beetle, had to extend the engine cover, but it was a body shop.
    A neighbor down the street put a 327 in an austin healey 3000, but that was before the toaster police were even a twinkle in eye of the general public. EVgo Limiting our Rights | PriusChat
    #32 vvillovv, Feb 20, 2021
  13. Prodigyplace
    12,551
    11,772
    Central Virginia
    You mean Corsair
    Or Corvair??
    vvillovv likes this.
  14. vvillovv
    4,321
    1,510
    NY
    Love the pics .... LOL ... tryin to think of a good way out of my total confusion, asked was the corsair also made by GM?
    2021LincolnCorsair.jpg Nope, it's a Lincoln. drats can't use that one..
  15. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Engine swaps are a real hoot; used to toy around with VW/Porsche integrations. Here's a fiberglass Benz replica I did many moons ago:
    Prodigyplace likes this.
  16. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Yup, that was one of my first thoughts. I’m glad the OP decided against doing that.
  17. MTN
    MTN Active Member
    306
    276
    SB, CA
    Ouch. Thanks for the feedback on rooftop boxes.
    My VW Sportwagen has ~180hp/tq 1.8T and gets 33-34 mpg with a (16 cu ft Yakima) box on top, at 70+ mph.
    Without the box, it holds about as much as the Prime + a box and gets 38-40 mpg.
    Looks like we've been right to take the Prime when everything fits inside and the wagon when more space is needed.
