2007 w/p1121coolant control valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gregwco, Dec 17, 2020.
  1. gregwco
    gregwco New Member
    Austin, tx
    Three Touring
    Hey, P1121 code so I replace my valve. Code came back, so I tested the old valve and it did its thing. Now I have two working valves. The electrical connection looks great. Could it have a short? Any thoughts or suggestions...
    Thanks, gregwco.
  2. JC91006
    JC91006 Senior Member
    16,482
    8,399
    Did you bleed all the air out of the coolant loop?
    Where did you get the replacement valve? Is it an OEM product?
    m.wynn likes this.
  3. gregwco
    gregwco New Member
    Austin, tx
    Three Touring
    Sorry, a lot of hours at work. Yes, the coolant system is clear of air and full. Dorman product, I have never had a problem with them in the past.
  4. JC91006
    16,482
    8,399
    There were others that have installed Dorman products and they ended up being defective.
    m.wynn and Raytheeagle like this.
  5. gregwco
    gregwco New Member
    Austin, tx
    Three Touring
    It has been functioning. The heater works fine. About 400 miles since the swap.
