Inverter 2010 233,000mi
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by erolbaybura, Dec 24, 2020.
  1. erolbaybura
    erolbaybura New Member
    Riverdale MI
    Hello everyone, Have a 2010 and sometimes the engine stalls on the interstate driving 70 mph, but it restarts every time so far. No problems at lower speeds. The dealership "scanned and found no codes present related to the IPM. Drove and found the engine water pump is failing causing the engine to overheat and shut down. Estimate $765.27 to replace engine water pump. Parts have to be ordered. Do not recommend driving due to engine overheating from failing water pump."
    Should there not be a code from the stalls?
    What do you recommend we do?
    We are gun-shy of dealerships. Would another have a different opinion?
    Love the reliability and mpg of this vehicle. Would get another Toyota. Watch a lot of Scotty Kilmer youtube.
    Thanks for all the fine information on PriusChat.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Usually an overheating will cause car to stall.pumps are around 160, see if you can find someone cheaper
    erolbaybura likes this.
  3. ChapmanF
    18,457
    If you do have to drive it any before the pump gets replaced, it would be handy to have some OBD-II tool or phone app plugged in and watch the coolant temperature.
    In fact, if it stalls again while you are doing that, please post the temperature at which it stalls.
    There was a recent thread here where I tried to do that in the driveway, based on a note in the Repair Manual that it will stop the engine at 105 ℃ if there is already a water-pump trouble code logged. But there is one way the pump can fail that 2010s didn't have a trouble code for (2011 added one), so in a 2010 if the pump fails that particular way, the ECU doesn't necessarily know it.
    In my driveway, with a working water pump and no trouble code, I was able to run the temperature up past 105 ℃ (by disabling the fans) and the engine did not shut down. Apparently when the pump isn't already suspect, the limit is higher. I just didn't find out what the higher limit is, because I went up to 107 ℃ and then chickened out.
    So if another stall happens to you, it would be helpful to post the temperature so we know what that limit is. However, I would not advise deliberately pushing the temperature just to find out. (Overheating is especially dangerous when it happens because of a pump problem, because the coolant isn't circulating so the engine isn't even overheating evenly.)
  4. erolbaybura
    Riverdale MI
    Thank you ChapmanF!
  5. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Consider buying another car.
    The Gen-3 Prius also has an issue where the EGR system clogs, usually at a mileage less than yours. This clogging also could lead to overheating and head gasket failure, a major repair.
    You could get the water pump replaced, and hope for the best, but you should also address the EGR system. The EGR cleaning (or component replacement) is labor intensive ($$). If you have the tools and a place to do it, the water pump simply bolts on to the engine. The EGR system takes more patience to do yourself, but most folks here have DIY-ed it.
    Have you had to add engine coolant, or have you ever experienced noticeable shudder shortly after starting the car?
  6. erolbaybura
    Riverdale MI
    Thank you pjksr02, Yes I did have to add coolant driving mi to az cross country on interstate. No shudder though. What car do you recommend/drive? I believe EGR cleaning would be beneficial. Searching now for a technician, most say go to the dealer. Love this car. got it for 4100usd, at 218,000 miles.
  7. ChapmanF
    18,457
    You might also consider an easy, non-invasive step, such as pulling up the value from the car's last EGR flow test, as part of deciding what kinds of work to prioritize.
    It is also (comparatively) easy to get just the intake manifold off, and clean its separate EGR passages into the four intake ports. That's the only part of the EGR system that is downstream of the MAP sensor and therefore 'invisible' to the computer that monitors and controls the EGR flow, and if those passages are clogged to different extents, that could mean that even when the flow overall is sensed as sufficient, it might not be right in all cylinders.
    If removing the manifold, I'd recommend new gaskets (they're cheap). They are the (somewhat) reusable thick rubber kind, which you can get away with reusing if, say, you have another reason to take the manifold off again in the future, but one that's been there since the factory is probably somewhat cooked and flattened.
    erolbaybura and pjksr02 like this.
  8. erolbaybura
    Riverdale MI
    That is excellent thinking. Intend to share this with my technician asap.
  9. Mendel Leisk
    41,825
    EGR (and intake) cleaning is a good head gasket preservation tactic, but if you're losing coolant the head gasket's likely already failing. A leak-down test could confirm. I would remedy the head gasket and immediately thereafter do the EGR/intake cleaning, and consider a oil catch can too.
    Info on EGR cleaning, plus oil catch can install:
    Bad Flywheel | PriusChat
    Head gasket rebuild, bundle of repair manual excerpts:
    Blown Head gasket rebuild....@297k | Page 15 | PriusChat
  10. pjksr02
    534
    227
    Connecticut
    Over the next days, you're sure to get many opinions on what work you should have performed. Read and analyze them.
    My thinking is that if it were my car, I wouldn't trust it for a long, important trip, since it could break down. You haven't spent big $ on repairs yet, so you could apply repair funds towards a used Corolla or Camry, for example.
  11. erolbaybura
    Riverdale MI
    Thank you Mendel Leisk and pjksr02. I am feeling more comfortable by the second. You're outstanding humans.
  12. rjparker
    10,411
    6,521
    You certainly need to get the water pump fixed as the first order of business. Otherwise it could get much more serious. I trust dealer's advice in cases like this but like others suggest, an independent hybrid experienced mechanic is my first choice if diy is not in the cards.
    I would then keep an eagle eye on the passenger side coolant reservoir. It should not use or lose coolant, period end of story. I would tell the mechanic to carefully check for external leaks after the water pump repair, not just at the pump but throughout the car. Coolant is flowing even to the catalytic converter and egr system.
    #12 rjparker, Dec 26, 2020
  13. erolbaybura
    Riverdale MI
    Thank you rjparker. I certainly will follow your kind suggestions. Learning at a rapid rate today.
  14. erolbaybura
    Riverdale MI
    I am still wondering why the stalls did not show up on the scan.
  15. ChapmanF
    18,457
    I know this thread says "inverter" in the title, but as near as I can see it is just a thread about engine overheating. I'm not positive there is a code for the engine stopping due to overheat. Seems like it would be worth having a code for, but I can't say that I've run across it.
  16. erolbaybura
    Riverdale MI
    Thank you sir. That certainly seems to make the most sense.
  17. erolbaybura
    Riverdale MI
    Will do. And thanks for the info.
  18. erolbaybura
    Riverdale MI
    Found the $160 water pump. See there is an inverter coolant pump too. Would we need both? Would the scan determine that? Feeling good about this fix.
  19. ChapmanF
    18,457
    I would just replace whichever one needs it. You can usually tell if the inverter pump is working by looking at the fluid in the inverter reservoir while the car is ON (just ON, not READY).
