Prius 2 Adding Front Fog dashboard Light inducate instruction
Discussion in 'Gen 2 Prius Technical Discussion' started by Kwm488, Jun 28, 2019.
  1. Kwm488
    Kwm488 Junior Member
    Hong Kong
    Hi
    I used two months to learn, tried and did many research. Finally , I am success to let my Prius 2 (no front fog) enable the front fog light inducate . Because I really hope my car look like original have front fog. So the wire, pin ,route which I do my best to follow.
    Please see the photo , it is step by step.
    Btw, I don’t have photo of adding front fog light and change the stalk. But it is easy to find it in YouTube.
    Ps. Need to change the stalk with front fog light switch .
    #1 Kwm488, Jun 28, 2019
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I know English is your second language, and you do very well. The word you should be using is "Indicator." Root word is "indicate." Inductor is a electric current pick up, electric buses that run off of overhead power lines have inductors which ride on the bottoms of the lines.
    plusaf likes this.
  3. Kwm488
    Hong Kong
    thank you very much
    plusaf likes this.
  4. Kammi
    Kammi New Member
    Germany
    Hello,
    where can i find the plug on picture 3.5?
    This is where the blue cable comes from the stalk and the yellow cable from the relay. But where exactly on the body ecu?
    Thanks in advance!
