What torque do spark plugs strip out?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Higgins909, Jan 2, 2021.
  1. Higgins909
    Higgins909 Member
    277
    68
    2010 Prius spec is 13 ft lbs. So did a bunch of work to my car and got a torque wrench out to do spark plugs. Not sure how accurate it is. I first set them all to 5ft lbs and thought it was in there more than what it took, to take out. (It was pretty dang loose) Then it was upped to 13ft lbs and 1-3 got it, but am worried about #4. (left to right, not sure of actual number) Got sketchy and stopped after about a half turn or so. I've driven it home, but don't now if I'm going to have a problem down the line. I'm praying the crush washer was stronger than the other ones, but do you think I started to strip it out?
    Thanks,
    Higgins909
    tangerino likes this.
  2. Mendel Leisk
    41,865
    Should be ok. Torque spec with clean/dry threads is 15 foot/pounds btw (see attachment from Repair Manual). Probably best to stay with clean/dry, but if you lube, say with anti-seize, maybe reduce torque by 25%, say to 12~13.
    The Repair Manual is a dogs breakfast btw: the attachment is a compilation from two section of the book. The main spark plug section makes no mention of spark plug torque. For that you need to go to valve cover removal instruction,
  3. ChapmanF
    18,503
    I've had some experiences that left me thinking threads tapped into aluminum holes have a limited lifespan, period. I once was reattaching an old transmission to an engine and the tapped holes in the aluminum bell housing stripped clean out at well below the original specified torque. Had take it back out and drill and heli-coil the holes. Happily, that's an established repair technology and works well, leaving a very lasting repair.
    Since then I've been much more cautious tightening anything into old tapped aluminum holes. I'll start with the specified torque as a goal, but if I don't like how it feels on the way there, I'll stop earlier.
    I've never had to heli-coil or time-sert a spark plug hole (he said, knocking a nearby wooden object), but they do sell kits for doing it, so it isn't a death sentence if the worst should happen.
    ... that's assuming there's enough aluminum meat around the hole to support enlarging the hole and adding the insert. The New Car Features manual said they went to the extra-skinny 12mm spark plug hole to make room for the four valves around it to be bigger, so it could be tight.
    tangerino and Mendel Leisk like this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    What is the range of your torque wrench? Torque wrenches should only be used from 20-100% of their scale. You may have been outside of your torque wrench’s accurate range.
    The newer Honda, Toyota and Nissan vehicles use extended length 12x1.25 spark plugs. Timesert has a kit for this. My machine shop just used this kit (supplied by me) to install an insert into a Honda J35 head.
  5. Mendel Leisk
    41,865
    Yeah 1/4” drive wrench is most appropriate, lower range.
  6. The Critic
    3,193
    2,333
    CA
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Mendel Leisk and The Critic like this.
  8. Mendel Leisk
    41,865
    Yeah 3/8” is in the ballpark too; in fact that’s the smallest I had when I had a look at ours a few years back. For 1/4” drive you can use an adapter; I have to do that more often than not.
    Then too, you need to convert to inch pounds, no big deal.
    The Critic likes this.
  9. Mendel Leisk
    41,865
  10. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Too rich even for your blood:whistle:?
  11. Mendel Leisk
    41,865
    Have a 1/2, 3/8 and 1/4, collected over the years. Always seem to be just under $30. The 1/2 I got about 35 years back. I did some recent testing with a digital pull scale: all seem ballpark, at least in mid-range.
  12. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    I have the same ones, just with less years on them;).
    Haven't done a calibration in awhile, as we haven't needed them:).
    But probably soon they'll be required, so I'll need to verify(y).
