Is this a normal about of corrosion for bus bars under a year old?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Jan 5, 2021.
Tags:
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    So I had to pull my HV battery today
    Replaced it in February and had two modules fail
    Got replacements from company I bought it off for free
    Noticed a lot of corrosion in the bars
    Is this due to excessive moisture?
    Is this a lot?
    I only say that because this prius does have water that pools up on the driver's side rear near the tail light / small storage bin
    Some input and advice would be greatly appreciated
    Also... due to a bad experience I just had with a local dealership I was offered a new complete pack for 1700 if I provided my current one as a core
    Good deal?
  2. PriusCamper
    PriusCamper Senior Member
    12,349
    5,014
    Pacific Northwest, USA
    Yes, that's fairly normal, but less common in dryer regions... As far as I know the only time this turns into a problem is where the orange voltage sensing harness plugs into the battery ECU socket. Once the corrosion gets in there it can short circuit the pins and fry the voltage sensing harness and sometimes fry the ECU as well. The symptoms for this problem is voltage block readings that are changing often and are wildly inaccurate/make no sense.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    You do realize that the "new" battery you got in Feb. really was NOT new.......right ??
    Sounds like your rebuilder did a poor job.
    kenoarto likes this.
  4. Banksy
    415
    132
    I absolutely realize that
  5. Banksy
    415
    132
    The bus bars were though
  6. Banksy
    415
    132
    Don't think I ever used the word "new" in my post
    Now this pack just fell about 5 ft onto the ground do to my bench deciding to give out
    Case doesn't look damaged
    Modules look fine
    Is this thing probably toast?
  7. PriusCamper
    12,349
    5,014
    I've found the most effortless way to clean bus bars is to put them all in a rock tumbler for a day or two...
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,020
    1,949
    NJ-USA
    Can't say for sure. My concern would be the shock at the module mounting screws possibly resulting in a crack. If it was still on the bench top as it fell (ie, the case itself didn't impact the floor) then I would think it was ok.
    The bare copper of the original bus bars corrodes real quick unless coated with something. I just got a set of the nickel plated bars from ebay.
  9. alftoy
    alftoy Senior Member
    1,132
    516
    Saskatchewan, Canada
    Ooops. Maybe take the dealer up on his $1700 offer.
  10. Banksy
    415
    132
    I was just looking at the quote
    That's with tax I think because it didn't mention any tax
    Just 1650 and the core
  11. ozmatt
    ozmatt Active Member
    631
    263
    Australia
    It is absolutely 100% moisture related and will ruin your battery (and rest of car) if you don't get on top of it asap..
    Seal the roof welds under tail gate, seal tail lights ..
    consider removing the little grommets in rear under corner tray and 12v battery so any water can drain if it does enter
    Put $2 shop dehumidifier containers in car and replace as required
    Good luck!
    donbright and PriFi like this.
  12. PriusCamper
    12,349
    5,014
    Maybe you can eliminate moisture in Australia, but where I live in Pacific Northwest we have the highest year round humidity levels in the country and there's no way you can eliminate it, you just have to live with it and minimize the damage it causes, which isn't that bad for most Prius owners.
    donbright likes this.
  13. ozmatt
    631
    263
    Australia
    its hard to control nature hey! i want more sun..
    its pretty "soggy" down south here where I am
    For me I just keep the vent on recirculate rather than open, keep car clean and dry, windows up and ac on .. as mentioned seal roof welds and put a few dehumidifiers in the car..
    You can keep it mostly under control if you are careful
  14. PriusCamper
    12,349
    5,014
    Our local Prius gang likes to coat everything in Di-electric grease to prevent corrosion and then when they ask me to work on their pack it's a huge mess and hassle for me and I complain bitterly. Have to wash my hands again and again when I work on those packs. Trying to prove to them that a little corrosion is way easier to deal with than my endless complaining about my hands and tools getting greasy.
    ozmatt likes this.
  15. ozmatt
    631
    263
    Australia
    Priuscamper, I'm so glad you mentioned this, have been considering the use of Dielectric but after reading this I definitely won't bother because I have a skin condition and washing hands too much is the best way to irritate them! thank you
  16. PriusCamper
    12,349
    5,014
    If you're putting in a brand new pack or reconditioned pack that's never had a bad module it makes sense to limit corrosion. But if your replacing a module your going to have to go in and do more work in 3 months to 3 years, so it's not worth the mess it makes.
  17. Banksy
    415
    132
    Do you have a link to those canisters you mentioned?
    also where could I get some more of the weather stripping that's on the hatch
    is that a common thing to cause this too?
    also.. di electric grease
    Do you apply it to the front and back of the bus bars?
    Or just slap it all over the front?
    #17 Banksy, Jan 10, 2021
  18. ozmatt
    631
    263
    Australia
    I am in Australia so you may need to do some searching your end of the planet but here is an example of what i use ..
    DampRid 300g Refillable Moisture Absorber | Bunnings Warehouse
    not too sure about the weather stripping mate sorry i will leave that for someone else :) but address the welds at the top of the tailgate where the rear panels meet the roof, i will be sealing one in the next couple days and will try to get photos if i remember
    I decided not to use grease its too messy for me, so not sure how to advise about that either sorry :)
  19. PriusCamper
    12,349
    5,014
    DampRid will get rid of very little moisture. When I have a prius that's get wet inside I put in my 40pint home dehumidifier and inside of car is super dry in less than a few hours.
    ozmatt likes this.
  20. ozmatt
    631
    263
    Australia
    No they are not for quickly extracting a real big mess,, its just a nice precautionary in the rear corners of clean dry cars after they have been sealed to collect any residual dampness in the cabin
    swap them out when the container is full which is about every 4 to 6 months for me
    & now that you mention it :) good idea.. I will grab a home unit the same as yours to use when giving cars annual once overs
    #20 ozmatt, Jan 12, 2021
