Cost of 12v AGM Battery for 2018 Prius
Discussion in 'Gen 4 Prius Main Forum' started by DaveWR, Jan 6, 2021.
  1. DaveWR
    DaveWR New Member
    Ottawa, Ontario
    2018 Prius
    I recently had to replace the 12v AGM battery on my 2018 Prius 5 and was shocked to see the sticker price of $690.00 Canadian plus tax! Hopefully this one will last longer than three years, but if I do have to replace it again I would like to hear about a less expensive option. Any ideas?
  2. Tideland Prius
    16,611
    That seems like a lot, even in Canadian dollars. My Gen 3 replacement cost was “only” $250 or $280 and that was from the dealer. On the Gen 4, it was around $200 from BCAA.
    I guess AGM is typically more expensive but wasn’t expecting 2.5x.
    It should last longer than 3 years. My Gen 3’s 12V lasted 7.5 years and probably longer but I just preemptively changed it at 7.5 years as preventative maintenance. On the Gen 4, it was changed out because it was drained twice already so its life was shortened and the 3rd time killed it (hence BCAA) - we suspect it was the dashcam that drains the battery when in accessory mode.
    alanclarkeau likes this.
  3. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I replaced mine last year in my 2016 model 4. I spent about $270. Even though I had scheduled in advance to have a new battery at my dealership, they didn't have one after I sat there for two hours. I went to a Pep Boys in town and they found one at a local auto parts store. It turns out these batteries aren't terribly common.
    Pulse07 and alanclarkeau like this.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    On fourth-generation (2016 and later) Prius cars, the auxiliary (12-volt) battery in the engine compartment, at least as originally installed by Toyota, is not an AGM type, so you could have used an ordinary (“maintenance free”) battery of the LN1, H4, or 140R size as a replacement. These are now readily available at auto parts stores.
  5. bisco
    52,353
    i would return it
    pilotgrrl and alanclarkeau like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    kithmo, Harters and alanclarkeau like this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It's not an AGM battery on a Gen 4.
    kithmo, Harters and jerrymildred like this.
  8. DaveWR
    DaveWR New Member
    Ottawa, Ontario
    2018 Prius
    My Toyota dealer said my 2018 Prius needed an AGM battery. Here is what I just found in "Torque News":
    "Because Prius only needs to have onboard computers turned to "ready" on, the load placed on the 12v is very minimal. AGM batteries are better in this regard to be able to wear better over time because they do not need to be cycled like flooded batteries do to stay at peak operating performance."
    Also, "Internal resistance also plays a critical role in what battery you should buy. The Toyota batteries are certified by Toyota to have the right internal resistance that will allow for proper charging. It has taken years for the aftermarket to start to get their Prius replacement batteries with the correct resistive values. Many new aftermarket Prius batteries would fail early due to poor product design"
    I am confused! Me thinks I will challenge my dealer on this one.!
  9. Elektroingenieur
    2,515
    3,287
    Three Touring
    That’s true for model years 2015 and earlier, and for Prius v and Prius c cars, which may be why the dealer is confused. You might suggest, if they have a new Prius car in stock, that they take a close look at its battery, and notice the vent caps and the liquid electrolyte inside.
    pilotgrrl, kithmo, Harters and 3 others like this.
  10. DaveWR
    DaveWR New Member
    Ottawa, Ontario
    2018 Prius
    Checked with the parts department at my dealer. They insist the Toyota AGM battery is the only one listed for the 2018 Prius and that any other battery would not give reliable service!
    I am going to talk with Toyota Canada to see if I can find someone there who can explain this.
    SFO and Mendel Leisk like this.
  11. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Almost sounds like an old-school deep-cycle regular battery would be fine at this.
    What's the difference between a normal car battery and a deep-cycle battery? | HowStuffWorks
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    Won't they come out and look at your battery that I assume came with the car new? Or, as @Elektroingenieur suggests, look at a brand new one in their own lot? Then ask them when AGM batteries started having caps you could unscrew to see the electrolyte inside that AGMs don't have.
  13. alanclarkeau
    7,045
    7,593
    This is mine - I suspect yours was similar.
  14. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I was at an auto part store in Colorado in the US and some lady was getting her 2016 battery replaced there, which is a H4 size (not AGM) and the price was $200 USD after core charge and that includes free installation if that is worth anything.
    pilotgrrl and kithmo like this.
  15. Mendel Leisk
    41,865
    I’ve been meaning to phone our local dealership parts dept, see what the current cost is for 3rd gen battery (mines in good shape, but over 5 years old now, so...).
    I’ll ask for 4th gen price and part no info as well while I’ve got them on the line.
    I’m on the west coast Canada. I know 5 years back they were asking $273 CDN for the 3rd gen Absorbent Glass Mat battery, the official (Yuasa) one. Funny how that price sticks in my head, lol.
    Kudos to @Elektroingenieur btw, a font of in-depth info as always!
    #15 Mendel Leisk, Jan 11, 2021
    alanclarkeau and Tideland Prius like this.
  16. Mendel Leisk
    41,865
    Open Road Toyota Port Moody quoted me just now: $541.41 (all prices CDN), for 4th gen battery, roughly 22% less (than $690). Part no is: 00544-065H4. I’d suspect it’s discounted vs full retail.
    For 3rd gen: $340.00, and this is an Absorbent Glass Mat type. Part no is: 8451P. Again, 5.5 years ago they quoted $273.
    I looked up batteries at Canadian Tire; they don’t have anything for 4th gen. FWIW for 3rd gen they do have one, for $249. I’d have no qualms about buying a CT battery (if and when available). I’ve bought them for a couple of Hondas recently, and they looked identical to OEM, apart from CT specific badging.
    @Elektroingenieur has mentioned various 4th gen aftermarket options in past, and above. They are maybe more US-centric though??
    Rant: my Honda battery purchases in past were always around $125~150. May have climbed, but still: these Toyota numbers are nuts!
    #16 Mendel Leisk, Jan 11, 2021
    Tideland Prius likes this.
  17. Tideland Prius
    16,611
    :eek: Is it because they're not replaced as often? That's expensive!
  18. Elektroingenieur
    2,515
    3,287
    Three Touring
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Apart from the non-spillage factor, what is the advantage of an AGM battery over lead acid ?
  20. alanclarkeau
    7,045
    7,593
    Higher cranking power for the weight I believe is the biggest advantage. Also can be smaller physically for the capacity - which might help manufacturers - who don't have to pay to replace them. In cold climes, they might hold a charge longer - I live in the semi-tropics, so can't test that out.
    Maybe the only advantages?? Flooded tend to last longer and are cheaper.
