Newly purchased 2008 stuck in driveway 2 wks till DMV appt
Discussion in 'Gen 2 Prius Main Forum' started by FLdreamin, Jan 4, 2021.
  1. FLdreamin
    FLdreamin New Member
    NY / FL
    Four Touring
    Sounds just like I have an angry seal growling underneath my hood -- found it on Reddit:
    davecook89t likes this.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    :), that's a funny comparison, but if you hear a "barking" noise while using the brakes, instead of an occasional "buzzing", that's not good. That is the most common description used by those whose actuator is on the verge of failure. If it actually fails, you will see several lights on the dashboard (typically Brake, ABS and VSC), at which point you will want to have the codes read to confirm, but if you are hearing the barking noise regularly, you need to prepare yourself for a major expense to have the actuator/accumulator replaced. Sorry to be a party-pooper.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    That should (try to) charge the 12 V battery but the HV battery will "cycle" between about 80% and 20% pretty much just like it would while driving but the cycles will be much longer.
    Sounds to me like you also need a multi-meter.
    The little red ones from Harbor Freight are more than adequate, for a bit less than $10.
    Similar models available at WalMart and auto parts stores for a bit more.
  4. Mendel Leisk
    38,711
    :cry:
  5. FLdreamin
    NY / FL
    Four Touring
    Okay, so after letting the car idle in ready mode for about 2-3 hours, I noticed the battery level on the MFD was down to 2 purple bars. Could it have been that I left the screen on for an hour or so? I also didn't leave the keyfob in car, but I don't think that would affect it.
    In any event, I force charged it (brake & gas) till the battery showed completely full green bars. I went out this a.m. and the battery held the charge. Whew!
    Will get the multi-meter on order, too! Thanks!
  6. davecook89t
    1,057
    789
    Four Touring
    That's normal, nothing to be concerned about. That number of bars corresponds to about 45% of battery capacity still remaining, well within normal operating mode.
    If you were going to leave the car unattended for many weeks or months, some members here would recommend force-charging the battery to 6 or 7 bars, because of the tendency of NiMH modules to self-discharge over time, but over the course of a week or 2, the amount of discharge on a healthy battery would not reach a level to be a cause for concern.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Not too many healthy 07 battery’s out there given how old they are now.
  8. davecook89t
    1,057
    789
    Four Touring
    I don't disagree. Last year about this time, I said as we were packing our 2007 for Florida, this will probably be its last trip. Guess what? It made it there and back and we are going to leave the Gen 4 sitting here in the Bronx again this year, and take the Gen 2 . My wife keeps saying she wants to buy a new car for herself (the Gen 4 is mine), but when she starts looking at my monthly cost for car payments and insurance, she always ends up agreeing to run the Gen 2 a little longer. I know one thing for sure, if we ever let it sit, as we do the Gen 4, that would be the end of it.
  9. Mendel Leisk
    38,711
    Not trying troll but cheeerist: do you have access to 120 volt outlet? Get a smart charge if possible, lol.
  10. FLdreamin
    NY / FL
    Four Touring
    Yep, my Noco Genius should be delivered tomorrow!
  11. Mendel Leisk
    38,711
    I forgot. :oops:
    Too many threads, not enough brain cells. :coffee:
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    That is NOT an unusual situation......and does NOT necessarily indicate any sort of problem, by itself.
    IIRC, the computer is set up to never let it get below a 20% SOC and the gauge does not show true SOC.
    So, when there are two bars left it is at something like 40%.
    Even seeing it go to ZERO bars for a brief time once in a great while does not necessarily indicate a problem, since that really is 20%.
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    Sorry if this is redundant, I don't have the will to review the whole thread:
    You do realize that will be useful ONLY for the 12 V aux. battery, right ?
    It will in no way be useful for the HV hybrid battery.
  14. FLdreamin
    NY / FL
    Four Touring
    Yes, absolutely! Although, it would be nice.....
  15. dolj
    dolj Senior Member
    7,648
    3,860
    Wellington, New Zealand
    Not quite, at least for Gen 2, which this forum is.
    2 purple bars = 43 - 47.5%
    1 purple bar = 40 - 44%
    0 bars = 39 - 40%
  16. Mendel Leisk
    38,711
    Hybrid battery can endure much longer down time. Owners Manual suggests 3 months as max IIRC. Two weeks is nothing.
