Any cases of Prius c EGR clogging and/or head gasket issues?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by farmecologist, Jan 7, 2021.
  1. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Hi all,
    There are tons of discussions about Prius Gen3 EGR clogging leading to head gaskets going bad ( well...that is the current theory anyway). And I think my 2012 Prius V may have the problem as well. :mad:
    I did a bit of searching and I can't find much discussion of Prius C EGRs and head gaskets going bad. Why is this?
    Note that from this thread, we do know that the Prius C has an EGR :
    Does the Prius C have an EGR circuit or not? | PriusChat
    So why are they not going bad? I can think of a couple reasons...
    1. Slightly newer model years.
    2. Orders of magnitude fewer of them on the road than Gen3.
    I'm thinking #2 is the main reason. Still...you would think a this point we would see some EGRs and head gaskets going bad if a design problem exists.
    Any other ideas? Could the fact that the EGR is near the top of the engine play into it ( see video in the link above )? Is the head gasket seal better on the Prius C engine?
  2. PriusCamper
    PriusCamper Senior Member
    12,351
    5,014
    Pacific Northwest, USA
    While Gen3 Prius Engines and Prius C engines aren't that different, in being on here every day I've yet to see an article for Prius C EGR valve cleaning, nor a Prius C head gasket blown post... But I'm not on all the forums so... I do remember once that I presumed that Prius C was the exact same as Gen3 with EGR issues and someone corrected me in a way that I agreed with and stopped lumping them together, but I don't remember the specifics.
  3. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    ...in the USA maybe.
    Keep in mind the Aqua, root model of the c, was the most popular car in Japan for years and was still in the top 5 for 2020. It's the Japanese F-150.
    You might not be finding cases due to a language barrier, but I suspect what's really going on is that the EGR on the c just isn't clogging up. And because it isn't clogging, the head gasket is not being subjected to overpressure. Less overpressure combustion = fewer breached gaskets.
    Remember, EGR has been a "consumer grade" engine management technology going back to the early 1970s. Plenty of engines have been equipped with EGR and driven for decades without clogging.
    It is important to remember that a cloggy design is the exception and not the rule.
  4. PriusCamper
    12,351
    5,014
    Lol, I'll never look at a Prius C / Aqua the same way again!
  5. farmecologist
    1,958
    1,799
    Southern MN
    Good point. I just looked up the Japan numbers and there are a lot of them out there. However, I'm not sure a Japanese person with EGR or head gasket issues would post here. (y)
    However, I think we agree that Prius c EGR's are not causing issues. I'm kind of stumped as to why that would be. If this is true...it kind of makes me want one! (y) I was postulating that it may be due to the location of the EGR near the top of the engine on the Prius c vs the side of the engine on the Gen3. However, I have absolutely no technical idea why that might be.
    @Leadfoot J. McCoalroller Could you verify that the EGR is near the top of the engine?
    Any tech gurus out there care to comment? (y)
  6. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    Er, can't directly. Which part of the EGR? It is fundamentally a passageway connecting the exhaust manifold (on the back of the engine) to the intake manifold (on the front) though the Prius version also includes a heat exchanger and a flow control valve, possibly more.
    I conjecture that the exhaust stream offered into the heat exchanger is too "dirty" which allows constriction by particulate accretion. If they tapped the exhaust from elsewhere in the system, the cooler might never have fouled.
    PriusCamper likes this.
  7. farmecologist
    1,958
    1,799
    Southern MN
    In this video : "
    At about 1 minute in...the EGR appears to be at the top rear of the engine...the shiny object at the rear of the engine. I think you can even make out the EGR pipe.
    @Mendel Leisk @Raytheeagle Thought you guys might be interested in this thread as well.
  8. Mendel Leisk
    40,983
    I thought Prius c engine was close to Gen 2: 1.5 liter displacement, and only a rudimentary EGR system, relatively bullet-proof.
  9. ChapmanF
    17,758
    Gen 2 used the 1.5 liter 1NZ engine and no EGR whatsoever.
    The c uses the "same" 1NZ engine, updated with an electric water pump and cooled EGR like the rest of Gen 3, as seen in that video.
  10. Mendel Leisk
    40,983
    Ok, so egr closer to 3rd gen, thanks.
  11. farmecologist
    1,958
    1,799
    Southern MN
  12. farmecologist
    1,958
    1,799
    Southern MN
    Here is a screen capture from a video..the EGR cooler is circled. It certainly does look like easier access than the Gen3. Looks like easier access to plugs as well. (y)
  13. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    Right but what's feeding that heat exchanger?
    Is it the "cool and dirty" flow coming right off the cylinder head, or is it the "hot and clean" exhaust from the catalyst?
    I gather that this forces them to choose between contaminant accretion from the former, or extra cooling load from the latter.
  14. ChapmanF
    17,758
    The liftbacks didn't switch to catalyzed EGR until Gen 4, MY 2016. The c was born around the time of the mid-Gen 3 refresh.
    The introduction of catalyzed EGR to the industry doesn't seem to have been just somebody at the water cooler saying "would we get less gunk if we tapped the pipe here?", but more like a spanking new EGR regime in its own right. The catalyst changes the chemistry, the changed gas does different things to combustion when returned to the cylinders, and the pressure is also lower, having dropped across the catalyst. Engine design and ECM algorithms re-tailored for it. Journal papers about it. Maybe some of those dates would indicate whether it would have been even a thing at the time the c was being designed.
  15. farmecologist
    1,958
    1,799
    Southern MN
    So...other than idle chatter, nothing very definitive here. (y)
    Could some of you Prius c owners check the 'EGR pipe' for carbon...like us Gen3'ers do?
  16. Mendel Leisk
    40,983
    Do they have a pipe? (n)
  17. ChapmanF
    17,758
    Why, yes ... yes, they do ... as was covered in some of the 'idle chatter' earlier in the thread. And shown in a rather large photograph in #12.
    farmecologist and Mendel Leisk like this.
  18. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    For that matter - do we have external catalytic converters?
  19. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    Yes, there is a catalyst. Relax, it's much, much smaller than the one everyone wants to steal. When they start catjacking every random Chevy & Honda on your street it'll be time to worry.
    I'd be happy to remove and inspect mine to add to the data pool, but I'll probably wait until 50 or 60k miles to do it.
    #19 Leadfoot J. McCoalroller, Jan 29, 2021
    Raytheeagle and PriusCamper like this.
  20. PriusII&C
    PriusII&C Active Member
    424
    142
    San Jose, California
    I do have a 2012 Prius C with about 110k miles. But I am NOT familiar with the EGR system, so don't want to mess with it unless there is a Youtube for me to follow.
    farmecologist likes this.
