Cams slipped need help setting it right
Discussion in 'Gen 3 Prius Main Forum' started by johnnychimpo, Jan 16, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    511
    109
    Monterey
    the cam slipped I put the colored gears back on the marks but no I'm not entirely sure if that's where it belongs does anybody have some pics of where the harmonic balancer should be or does it matter also the top cans are lined up with the chain markings along with the bottom chain on the dot in the lower crankshaft gear
  2. johnnychimpo
    511
    109
    Monterey
    IMG_20210116_081554.jpg IMG_20210116_081606.jpg IMG_20210116_081557.jpg IMG_20210116_081554.jpg IMG_20210116_081557.jpg
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    302
    Tropical Buffalo NY
    Four Touring
    The key (pun intended) is getting the colored links on marks....see video below.
    Once you have it timed the harmonic balancer is keyed to only fit one way on the crankshaft.
    Prius new timing chain - YouTube
  4. ASRDogman
    ASRDogman Senior Member
    5,894
    3,161
    I don't mean this in a derobatory way... Did you read up on, or watch any videos on how to
    install the timing chain before starting this job? :)
    After everything aligned, and you've released the tensioner, rotate the engine 720 degrees.
    2 complete turns. All the timing marks should line up again. I'm not sure if the colored links will
    or not, but it doesn't matter as long as the marks do.
    Just take your time, and go slow...
  5. ChapmanF
    15,072
    The colored links won't, not after two crank turns. You will eventually return to all-the-pieces-lining-up again (assuming the timing is right) but it takes on the order of a few dozen crank turns, or about the ninth or tenth time you see the colored chain links go by.
    The pictures of the cam sprockets show the links in the right place. I believe if the crank pulley/balancer is removed, you should be able to get a shot in through that hole that shows the colored link and the dot on the crank sprocket. That photo isn't included upthread, and that's the piece I don't trust. The photo of the crank pulley does not show it at TDC, at least assuming the light-colored spot on its edge is the ignition timing mark.
    Mendel Leisk and ASRDogman like this.
  6. johnnychimpo
    511
    109
    Monterey
    I did now I'm getting ignition coil primary secondary circuit malfunction. On a b c and d
  7. johnnychimpo
    511
    109
    Monterey
  8. ChapmanF
    15,072
    Seems to be pretty hard to see in there past the oil seal. My bad. (Maybe I was thinking of pics somebody took before installing the seal.)
  9. johnnychimpo
    511
    109
    Monterey
    I think the timing is fine it runs a little rough then idle's fine then chokes and dies I'm getting these error code something to do with the map sensor any suggestions Screenshot_20210116-145658.jpg
  10. Mendel Leisk
    38,210
    That’s the pop-mark on the end of the crankshaft?
    (Just beyond my funky arrow)
  11. ASRDogman
    5,894
    3,161
    I've seen the mark before the timing cover is on.
    That's why you should turn it over, before the cover is in place.
  12. ChapmanF
    15,072
    Ah, yes, that does look like the yellow link.
    I was expecting it to be more at the three-o-clock position. Was the camera just held at a funny angle?
  13. johnnychimpo
    511
    109
    Monterey
    Yeah getting the camera in there was a little bit tough you can see it but there was no light I had to angle it just right but what are you guys think does it look correct
  14. johnnychimpo
    511
    109
    Monterey
    I cleared all the codes but now I'm getting a misfire on cylinder four but without a code all those codes I got I cleared seems to be fine any suggestions
  15. johnnychimpo
    511
    109
    Monterey
    OK what if they dont is there a do it from scratch process?
  16. johnnychimpo
    511
    109
    Monterey
    is it possible to have the timing chain on the link mark but be off by a tooth due to too much slack on
    #16 johnnychimpo, Jan 16, 2021
  17. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    Need to pull the timing cover again. Looks like you are a tooth off at the crank.
    My guess is that your marks were lined up, but you left slack on the wrong side of the chain drive. All of the slack needs to be on the side with the tensioner.
  18. johnnychimpo
    511
    109
    Monterey
    Thank you sir that was my fear....I will jump on this at first light. I will report back. this caused me multiple sensor issue not sure if related. but definitely misfire on cylinder closest to EGR.
  19. Mendel Leisk
    38,210
    Cylinder #4, at right end as you stand at front?
  20. johnnychimpo
    511
    109
    Monterey
    Am I correct in this?
    Ok then with cylinder 1 at TDC (closest to the cahin)
    the exhaust dot should be straight up and the intake dot should be at 39 degrees (how exactly do you know where that is?????) assuming you get it right then the crank prior to taking the cover off should have the crank pully at 0 with the marking on the cover.
    once cover is off like I said now the last colored link should have the chain taught and lined up with the only link (no slack) to the dot on the gear. ALL Slack on the left and then you should get the chain tensioner to release and crank a couple of revolutions to ensure things line up again
    I my process correct here?
