ICE runs in EV Mode only in cold weather
Discussion in 'Prime Main Forum (2017-2022)' started by Stevarino, Jan 22, 2021.
  1. Stevarino
    Stevarino Junior Member
    Palo Alto, CA
    2020 Prius Prime
    On school drop off this morning, with 100% charge on the battery of a 2020 Prius Prime, the ICE (gas motor) would start and not shut off. It was 0 degrees fahrenheit, so I wonder if the HVAC systems couldn't be supported by the basic battery only architecture. 'Curious as to what others have experienced.
  2. Mendel Leisk
    41,908
    It’s 0F in Palo Alto, California? That’s part of greater San Fran, right? Or you’re currently elsewhere?
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Quarantine school must also start early:whistle:.
    I'm sure we'll get more details soon(y).
  4. Mendel Leisk
    41,908
    Ah, that’s true. 6 am’ish. (n)
  5. Stevarino
    Palo Alto, CA
    2020 Prius Prime
    'Sorry. We are currently in Minneapolis - Lowry Hill neighborhood. Waldorf school here runs a tight ship, so we have in person classes. The school is one mile from home, with a 25 mph speed limit and a handful of stop signs.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    At temp below 14F, the heat pump will not work to heat the cabin, so if you had HVAC set to heat the cabin the engine will come on even in EV mode. Yeah, at 0F you need all the heat the engine is producing and otherwise wasting. At that low temp, I usually switch to HV manually to save the EV range for later use. Even at that temp, the car will go into EV drive but the engine will come on frequently.
    #6 Salamander_King, Jan 22, 2021
  7. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    On my 2020 Prime, I've found that if the battery temperature is even a few degrees below freezing the computer limits the amount of power you can draw out of it. One good stomp on the accelerator and the ICE starts up.
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    It must be quite a shock going from the Bay Area to Minneapolis in a Prime. It'll really act differently.
    Don't hate me, but as for us, we ate lunch outside today at a place about eight miles from home. Had to run the A/C while driving. Still got 5.2 miles/kWh since it was all 35-40 mph. :D
    Henrik Helmers likes this.
  9. Stevarino
    Palo Alto, CA
    2020 Prius Prime
    Thanks, @Salamander_King. That makes perfect sense given that the Prime is an ICE car with a battery pack, and Toyota likely kept the HVAC system for all Prius'. I guess we can just not use heat and hold our breaths - or replace it with a BEV.
    Salamander_King likes this.
  10. bisco
    52,393
    -17c, that's the problem. seat heaters
  11. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    I read somewhere that at -14C or 7F the ICE automatically comes on to protect the battery. That's what our 2018 does. Thankfully we've only had very few of those days this winter (Alberta). Although we're gearing up for a 5 day stretch of -25C shortly!
  12. Trollbait
    12,688
    That and there isn't enough heat outside for the heat pump to gather for the cabin.
  13. Henrik Helmers
    Henrik Helmers Active Member
    100
    148
    Norway
    2020 Prius PHV
    I’ve been able to drive in EV mode in -20C, but if you want heat the ICE will take a loooong time to reach operating temperature. Eventually there are bursts of battery usage though.
  14. IABoy987
    IABoy987 Member
    214
    86
    Iowa
    2018 Prius Prime
    I "accidentally" started a thread on exactly this problem under another forum, as being a relatively (and I hate my relatives!) new prime owner, was surprised when the engine would start. I reread the owners manual thinking I had accidentally pushed a button that took car out of exclusive EV mode. But now I know why this is happening. All my pre-Prime experience was with regular priuses with engine staring stopping as needed.
    This ole dog learned something new!!
  15. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    Since the past weeks have been extraordinarily cold, I have gotten some more practice. Here is what I've learned so far:
    • I park in an unheated attached garage, where it never gets colder than -8°C. This is enough to pre-heat the Prius plug-in. So I pre-heat in two rounds.
    • The "engine start" temperature seems to be what is shown on the dashboard. This adjusts slowly. Meaning that I can usually start in EV mode, and keep the heat on for a couple of minutes until the vehicle realizes how cold it is. I stop when the meter falls below -10°C.
    • If you go long enough without the climate controls on, vater vapor will fog up your window; forcing an engine start for safety. The colder it is, the slower the buildup. Brrr!
    • The ICE firing up doesn't seem related to having the climate controls set to ECO or FAST.
    Tideland Prius and jerrymildred like this.
  16. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    February is nearing its end, and temperatures have been above freezing for about a week. What a difference that makes when driving the plug-in!
    Today I successfully completed a fairly long trip on electricity only. I expect this to be the norm for the next ten months. :)
    rbwilli, jerrymildred and walterm like this.
