BT Tech stiffening plate question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by dmarcus123, Oct 14, 2006.
  1. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(DocVijay @ Oct 16 2006, 08:41 PM) [snapback]333765[/snapback]</div>
    I love this! You guys (and gals) are entirely too serius about this s--t. If you think it works, wonderful. If you think it doesn't work, just as wonderful. But, if you've never tried it and claim it can't possibly work, I'm sure you can see where you just might be on shaky ground. But, that's what makes this forum better than TV re-runs.
  2. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(syclone @ Oct 16 2006, 10:32 PM) [snapback]333817[/snapback]</div>
    Sure you don't mean Jerry Springer?
  3. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(windstrings @ Oct 17 2006, 11:48 AM) [snapback]333937[/snapback]</div>
    Walk this way please! :rolleyes:
  4. BT Tech
    BT Tech New Member
    885
    South Florida
    I thought that it would be better to post this here that to respond to each individual PM that I have received.
    If you want to purchase one of our stiffening plates you can either call us directly at the number listed below or click on the link below and it will take you directly to the Prius Chat online store.
    We currently are down to aproximately 30 pcs in stock and will be receiving another production run in about 4-6 weeks.
  5. windstrings
    6,280
    378
    Central Texas
    Do you know about how many you have sold so far?.. if you care to share?
    I've been following these since Nov 05 and they have been selling like hotcakes every since then... I bought two myself!
    It would be interesting how many are out there!
  6. BT Tech
    BT Tech New Member
    885
    South Florida
    I would have to check our records but it would be suffice to say that there are quite a few Prius' out there with our stiffening plate attached to them.
    I was pulling into a parking lot the other day and parked just 3 cars down from me was another Prius. I just had to neil down and take a look to see if it had one of our plates on it and sure enough there it was!!
    I waited around for a few minutes for the owner to come back to their car but it was getting late and I had to go and finish up my shopping!! :)
    <div class='quotetop'>QUOTE(windstrings @ Oct 17 2006, 11:36 PM) [snapback]334285[/snapback]</div>
  7. New Revelation
    New Revelation The Master Captain
    180
    Liberty, TX
    Hm, I have no doubt that this plate would help in handling, but it is expensive though for just a small plate. May look into it sometime next month when I get my Prius.
  8. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Hopeful Future Prius Owner @ Oct 19 2006, 05:49 AM) [snapback]334960[/snapback]</div>
    It looks pretty simple, but its very light and machined out of a solid piece of high quality aluminum.
    You may be able to make your own, but it may rust unless you use something that won't rust, but it's hard to find that without it being too weak.
    If it flex's, your no better off than you were.
    I know it sounds like alot of money when its not included in the loan, but anything on a car will cost...even a decent license plate cover is 20.00.
    I figure, some things are worth being cheap on, others are not.. when it affects the whole car, I'm into "not" being too cheap..... you may have to wait till your in the mood.. it sounds like he is almost out of this production anyway till he gets another.
  9. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(Presto @ Oct 16 2006, 09:05 PM) [snapback]333804[/snapback]</div>
    Yes; this is precisely why finger quotes were invented!
  10. chimohio
    chimohio New Member
    460
    <div class='quotetop'>QUOTE(syclone @ Oct 17 2006, 12:02 PM) [snapback]333940[/snapback]</div>
    Don't you mean Dance this way?
  11. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(prius biker @ Oct 19 2006, 06:43 PM) [snapback]335288[/snapback]</div>
    No. It's a reference to Marty Feldmens's roll as Igor in Young Frankenstein.
  12. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(syclone @ Oct 19 2006, 10:42 PM) [snapback]335392[/snapback]</div>
    That was a reference to Groucho Marx.
  13. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Ken Stewart @ Oct 16 2006, 08:18 PM) [snapback]333814[/snapback]</div>
    Wrong! Belongs at the metal recyclers. We can't afford to be stuffing steel into landfills. But I'm sure you meant "recycle" when you said "trash" yes?
  14. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(Godiva @ Oct 19 2006, 11:45 PM) [snapback]335394[/snapback]</div>
    That may be correct, but look at Windstrings avatar.
  15. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(syclone @ Oct 20 2006, 07:06 AM) [snapback]335457[/snapback]</div>
    Did someonw say Dance? :wub:
  16. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(windstrings @ Oct 20 2006, 08:44 AM) [snapback]335473[/snapback]</div>
    Igor! Go to your room.
  17. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(syclone @ Oct 20 2006, 09:20 AM) [snapback]335521[/snapback]</div>
    Yes, Masta.... :( :( :(
  18. BT Tech
    BT Tech New Member
    885
    South Florida
    I must say Windstrings, you've got a "killer" avatar!! :)
    <div class='quotetop'>QUOTE(windstrings @ Oct 20 2006, 11:29 AM) [snapback]335562[/snapback]</div>
  19. chimohio
    chimohio New Member
    460
    <div class='quotetop'>QUOTE(syclone @ Oct 19 2006, 11:42 PM) [snapback]335392[/snapback]</div>
    I was referring to Jerry Springer on Dancing with the Stars.
  20. Godiva
    10,339
    Igor's "Walk this way" in Young Frankenstein was an homage to Groucho Marx.
    So it's an homage of an homage.
