P3190, P0a0f-204 2006 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by golddigger, Jul 28, 2020.
Tags:
  1. golddigger
    golddigger New Member
    Kingston, Canada
    Could use some help here.
    So car is nearing 600,000 km's or 375,000 Miles.
    Got a P3190 and P3191 codes.
    Cleaned the air intake as there was some oil residue at the bottom.
    Cleaned the throttle body and MAF
    got a new 12v battery
    Cleared the codes, and the car ran for about 10kms/6 miles.
    Same issue presented itself. But only code 3190.
    Replaced the spark plugs, replaced the PCV valve, New maf sensor as I cleaned the other one with brake cleaner. (my mistake)
    I now get code 3190 and P0a0f -204
    12v battery even though new is on the charger at the moment as I take a moment to gather more information on the issue.
    Where should I go from here?
    48,996
    do a load test on the battery after charging
  3. douglasjre
    douglasjre Senior Member
    1,774
    617
    Orlando, FL
    What was the solution?
    SFO likes this.
