Brake light comes on while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, Dec 29, 2020.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    Occasionally during driving i will see the red brake light come on for a few seconds, then it will turn off. I made sure the parking brake wasn't engaged. I did not do any brake work , this issue just started happening recently. 20201229_175229.jpeg
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    It may be the brake light switch on the emergency brake.
    I would check the brake food reservoir under the hood it may be low. But i think there's another brake code for that never seen that personally.
    #2 edthefox5, Dec 29, 2020
    SFO likes this.
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    This morning I saw the lights for ABS, VSC, emergency brake all come on. After 1 minute they went off. When I checked the codes I did not get any result. Could that also be symptom of low brake fluid?
  4. bisco
    51,814
    how is the 12v health?
    what code reader?
  5. Berch1943
    Berch1943 Member
    146
    Arizona
    No idea , I got that replaced 2 years ago. I checked using Torque pro
  6. Mendel Leisk
    41,258
    Check it? Normally you’ll never have low fluid; it falls slightly as pads/shoes wear, rises when they’re replaced (as pistons are pushed back). On our 3rd gen (fwiw), level drops about 1/2” when you open drivers door which triggers the pump.
