Spark Plugs Prius 2007, 150k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MathWeijzen, Jan 25, 2021.
  1. MathWeijzen
    MathWeijzen Junior Member
    74
    Netherlands
    Thank u, but im no stranger....still no movement whatsoever.....
    In my opinion inverter pump always runs as in IG mode , 12 V, no HV.
    #21 MathWeijzen, Jan 27, 2021
  2. MathWeijzen
    74
    Netherlands
    why should the hybrid system be ready for this..for the inverter to run i doubt it..?
  3. Mendel Leisk
    38,710
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Don't understand your question.
  5. Mendel Leisk
    38,710
    I think he’s misunderstood “ready”, in the context of meaning the car is fully on. It’s mainly a Toyota term? His native language is Dutch.
    edthefox5 likes this.
  6. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Thank you didn't look at his location.
    Tried to explain the READY to him. Just turn the car on like your ready to drive. Put it in park open the hood and look.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    The car is not required to be in READY for the Inverter Cooling Water Pump to run. It only has to be in IG-ON. Two presses of the power button with foot off the brake. It makes it a bit easier to check for turbulence and pump noise when the engine can't start. Eliminates any doubt.
    Mendel Leisk and Aaron Vitolins like this.
  8. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    I think this is what MathWeijzen was trying to get across.
  9. MathWeijzen
    74
    Netherlands
    Exactly....
