2005 Prius bad EGR valve?
Discussion in 'Gen 2 Prius Main Forum' started by Prius Rising, Apr 23, 2019.
  1. tidesofthesky
    tidesofthesky Member
    61
    49
    Salem, OR
    Patrick, thank you so much for that explanation. I had read a little about the atkinson cycle, it helps to see it in practice.
    And the pcv has not been replaced that I know of, so I'll try to replace that today!
  2. ChapmanF
    18,427
    How strange that they wouldn't include a hole for the pin to lock in, but would still include the pin and the spring.
    It's true that I don't remember seeing any mention of the compressed-air unlock-the-pin business in my Gen 1 manual. I noticed it in the Gen 3 (2ZR) manual and thought, huh. what's that about?
  3. tidesofthesky
    61
    49
    Salem, OR
    Yeah it is really weird that everything is there except the pin! I was pretty worried about the whole thing rotating. But glad to at least have cleared up the confusion. I wonder why they skipped that system on the genII.
  4. ChapmanF
    18,427
    I thought your video showed the pin. And the spring. Everything except the hole!
  5. tidesofthesky
    61
    49
    Salem, OR
    My bad, you're correct. Its been a year or 2 since I pulled it apart
