Guys I need an exhaust.
Discussion in 'Prime Main Forum (2017-2022)' started by Storm88000, Feb 4, 2021.
  1. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    I’d rather not just get an OEM one, something maybe more performance related and less expensive?
    oemvehicleparts has the piping and muffler for $480 shipped:
    https://www.oemvehicleparts.com/oem-parts/toyota-muffler-and-pipe-1743037a70?c=Zz1leGhhdXN0LXN5c3RlbSZzPWV4aGF1c3QtY29tcG9uZW50cyZsPTEwJm49QXNzZW1ibGllcyBQYWdlJmE9dG95b3RhJm89cHJpdXMtcHJpbWUmeT0yMDIwJnQ9bGUmZT0xLThsLWw0LWVsZWN0cmljLWdhcw%3D%3D
    Cheapest OEM Toyota I found.
    so, any recommendations??
    #1 Storm88000, Feb 4, 2021
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Your car is almost new. What happened to the system it came with?
    Unless something destroyed it, the best and cheapest I know of is the one presently installed. Save the money for something you will eventually need to replace -- in 10-20 years.
    douglasjre, Montgomery, MTN and 3 others like this.
  3. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    long story but what looked like a frozen chunk of snow in the middle of the highway partially crushed the pipe when drove over it. thought I’d clear it. Muffler and tip are fine. Extremely upset but calm now. So asking if anyone has done any exhaust mods for that reason.
    #3 Storm88000, Feb 4, 2021
    jerrymildred likes this.
  4. ETC(SS)
    7,134
    Yes....
    ...Don't!
    Couple of pretty good reasons:
    1. If you sell your car with a non-OEM exhaust installed it's going to lead to speculation. Was the car wrecked? Did the owner trash the original exhaust because they don't know how to drive? Was it rode hard and put up wet? Auto crossed?
    2. "More Performance" for closed loop fuel management systems usually only means "more noise" which leads to questions generated in #1 above. Sometimes....if you REALLY "tune it up" you will also reduce fuel efficiency AND generate more noise.
    Read up on Atkinson cycle engines to see why this especially true with YOUR car.
    3. If you really have to scratch this itch, get a bolt-on cat-back system but find a way to keep the OEM parts so that your car won't look quite as sketch when you trade it in.......or?
    Go to an automotive parts house and get one of those exhaust tips that you put on with a set-screw.
    All of the class and performance at a fraction of the price.
    OK.....I just read your latest post which sorta validates #1 above.
    See if an exhaust shop can repair the pipe while verifying that there's no under-hull damage. This is especially true if there was no accident report or insurance claim. You can replace any plastic fairings that were scrubbed off by buying them on-line or used.
    MAKE SURE that there are no other "mods" present under the car.
    If your vehicle's vin # was placed on an accident report or you filed a claim, then you're already driving a "previously wrecked" car as far as the world is concerned.....so you'll be free to go wild with the mods!!
    Good Luck!
    ETP, Merkey and Storm88000 like this.
  5. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Thanks. No damage underneath just the pipe at its lowest point. It’s significantly narrower. I was also thinking about just having an exhaust shop fabricating new piping and welding it to my OEM muffler?
    ETP and MTN like this.
  6. ETC(SS)
    7,134
    A decent exhaust shop can cut out the damaged section and weld in a replacement in no time, and probably not for all that much money. Get a couple of guestimates - or just go with the shop with the best street cred.
    BEWARE internet ratings.
    They're a lot like poll results.
    VERY malleable.
    Money is tight.
    There are probably some good shops that would be happy to have the work.
    Good Luck!
    #6 ETC(SS), Feb 4, 2021
    douglasjre, ETP, MTN and 1 other person like this.
  7. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Glad to hear. Oddly the car doesn’t sound or drive any different. Would kind of think a crimped pipe would hurt power but it didn’t seem too. But not pushing it til fixed.
    I am talking calmly now about not, but I was anything but when it happened. We had 28” of snow over weekend and there are chunks of snow and ice everywhere. I just didn’t see this one, too much traffic.
  8. ETC(SS)
    7,134
    It happens.....
    BTDT.
    ETP likes this.
  9. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I once ran over a COUCH in the middle of a major highway. I swerved but passenger side ended up running it over. It was already in like 4 pieces but it was a random couch just sitting there. Couldn’t believe it. And I remember suddenly my exhaust got extremely loud right away, so I knew what happened. This was back circa 2008 in a 1994 Nissan Sentra. Lol.
  10. jerrymildred
    11,517
    14,148
    Tampa, FL
    Amazing, all the junk on the roads.
    Ditto to @ETC(SS) first comment on shops. My exhaust shop experiences were long ago, but even then they could bend and weld in a new piece in no time flat. I think I'd do that and not even think about the dealer unless the shop says you need to go to the dealer for something special, which seems unlikely.
    ETP and Storm88000 like this.
  11. Trollbait
    12,505
    The computer will adjust how the engine runs to keep things in spec, which is why performance parts need a tune to work, and the cat probably is the most restrictive point in the exhaust.
    Storm88000 likes this.
  12. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    *^ Makes sense. You guys are so knowledgeable. :) :) thanks.
    Cheapest OEM I found is a brand new piping and muffler for $480 shipped on oemvehicleparts.com.
    I see eBayers selling the latest Prius gen muffler itself w/ the tip for $250. That would be great if I can even get $150 for it to offset the costs. Maybe someone needs one. Who knows?
    I have to figure out what to do. You guys see this was the LAST thing I ever expected to be dealing with, with this car. I wanted tinted windows some 16” darker wheels and maybe some TRD side skirts - did not expect to come across a boulder of ice and snow and lead me to thinking about exhaust mods.
  13. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Btw pic of the muffler. So upset.
    it’s just a car I tell myself, it will be OK:
    Muffler came off the hanger:
    Ready to see what the giant ice/boulder/snow thing did when I went right over it? It’s cringe worthy:
    look at the crimp on the right side, and the left side is smooshed. Ugh. Why me
    Raytheeagle and jerrymildred like this.
  14. jerrymildred
    11,517
    14,148
    Tampa, FL
    OUCH!!!! Now I don't feel so bad about this morning's "cold" weather here. 37º when I got to work and only got 3.0 miles/kWh rather than the typical 5+. No chucks of ice; just some light windshield scraping.
    That looks like it must have been a nasty surprise.
  15. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I thought the wheel fell off. Like the rear passenger wheel. It was so loud. I had a split second chance to see it in the road as bunch of trucks ahead of me swerved around. The trucks cleared it, but I swung around it and somehow ended up with it going under the side of my vehicle, like the around the rear passenger tire.
    saving grace: I MISSED IT WITH THE FRONT END. We know how low the front ends are on our cars. I would rather replace some exhaust piping than the entire front bumper.... if there is a silver lining ...
    #15 Storm88000, Feb 4, 2021
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  17. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Excellent! Now I just have to find out where it is and what shipping cost is - thanks!
    btw if anyone else sees any please let me know. Thanks Jimbo!
  18. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Doh! I spoke too soon. They want $288 for shipping which is almost $440. Only $40 less than the price oemvehicle.com wants for a brand new one shipped :( I’ve bought from them before and they are quite good.
    I’ll keep checking. Was wondering if anyone here put on their own aftermarket exhaust for whatever reason and had the OEM one sitting taking up space. Willing to drive 4 hour radius of PA/NJ.
  19. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Check auto salvage yards in your local area. If they don't have it, they can usually find it.
    ie in Allentown: Essington Avenue Auto Parts
    Storm88000 and Trollbait like this.
  20. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    You hit an object on the highway. That may be an insurance claim on your comprehensive coverage if the final cost runs high enough and your deductible is low enough.
    Montgomery, Mendel Leisk, ETP and 2 others like this.
