Anyone using China Iridium spark plugs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ozmatt, Feb 8, 2021.
  1. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Best of luck with your Chinese plugs mate. You get the government you vote for.
  2. ozmatt
    ozmatt Active Member
    604
    251
    australia
    Bob, no its not bad :) just being a fool as usual ;)
    CHeers mate, i am pushing away from China Iridium and heading towards local brand Platinum, hopefully the Prius can energize them properly as im sure they wont be as efficient
  3. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    Hey Matt, given what you have said, I would probably just use regular (read cheap) copper spark plugs and change them every 30,0000 km. You'll still be quids ahead. I agree with your assessment that these Prii aren't worth long-life iridium plugs.
    ozmatt likes this.
  4. ozmatt
    604
    251
    australia
    Thanks Dolj :) yeah if I put iridium in this particular old car they would probably end up at the scrap yard with about 96% of their useable life left in them! I can not stand waste hence my obsession for fixing up these old cars in the first place!
    there is a clearance deal on platinums at one of our leading auto parts stores at the moment, is there any reason not to use those over coppers?
    Matt
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    One phrase: "Toyota Maintenance Yootoobe Channel"
  6. ozmatt
    604
    251
    australia
    Can anyone advise if Bosch WR8DP will work ? i can get these for virtually nada
    looks like the spanner size is 21mm not sure if that will cause an issue or not
    or.. Bosch FR8DC
    #26 ozmatt, Feb 9, 2021
  7. dolj
    dolj Senior Member
    7,648
    3,859
    If you can get them for a similar price as standard copper plug, then why not? Even if they were twice the copper price it would make sense if the car would go another 95,000km.
    I don’t know about your Bosch question. I’ve never used Bosch myself. You would need look up a manufacturers cross reference table to find the equivalent of the OEM Denso or NGK.
  8. ozmatt
    604
    251
    australia
    Cheers for that dolj :)
    Ended up with two sets, FR7DPX for a couple bucks ea and FR8DC+ for 0.90c ea
    Not optimum head rating on the 7s and may need to adjust the gap but meh, it might compensate for the mileage lol
  9. dolj
    dolj Senior Member
    7,648
    3,859
    No worries.
    It would be useful if you could do a follow-up post on how the car went on those plugs. I, for one, would be interested in that.
    ozmatt and SFO like this.
  10. ozmatt
    604
    251
    australia
    Too easy Dolj definitely will, be quite surprised if these plugs die before the cars do
    Been wondering if the fr7dpx will help a little with engine ping, or just foul. From what i understand of it (Bosch) heat range 7 would be a closer match for a gen3, they are one stage colder than the recommended Bosch plug for a gen2 which is range 8, all other spec seem to be the same from what i can tell, just not iridium.
    FR8DC+ should be fine for a gen2 re-gapped to 1.1mm, all other spec seem to be the same, other than not iridium.
    btw I did not purposely select these plugs they were simply what was dramatically discounted for clearance at our local parts store
    dolj likes this.
