Does a 2016 Prius Four have the a lithium hybrid battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by Banksy, Feb 10, 2021.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I read somewhere that some of the 2016s had the older style batteries in them
    I’m interested in a 2016 Prius for with 85k on it and want to know if it’s a newer style battery that’s in it
    Also is 12k a good deal on that car if it’s in very good condition?
  2. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    You are asking about a Prius 4 (I assume you meant "four" rather than "for"), correct? It has a Lithium Ion main battery, as do all the other trims except the Prius 2.
    Banksy likes this.
  3. Banksy
    415
    132
    Yes, I am talking about a four
    all the twos have the older style ones?
  4. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Raytheeagle, Banksy and davecook89t like this.
  5. davecook89t
    1,089
    825
    Four Touring
    Yes, I believe the Prius 1 had the NiMH battery as well as the Prius 2, if you should happen to come across one of them. I understand the Prius 1 was only sold to local governments.
  6. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The AWD-e (mine is a 2020) has the older NiMh battery pack. My 2016 Prius 3 had the Lithium Ion battery pack.
    JeffD
    Pulse07 and davecook89t like this.
  7. davecook89t
    1,089
    825
    Four Touring
    Right, I could have mentioned that, but I don't believe a 2020 model will be within his price range.
  8. Elektroingenieur
    2,515
    3,283
    Three Touring
    I’ve posted a cross-reference to grades (trim levels), VIN prefixes (WMI/VDS), model codes, and HV battery types.
    davecook89t and SFO like this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I wouldn't worry either way - it has little bearing. Both have the same tested MPG/l/100km. Most of the world got NiMH, only Japan and some models in America. We still get NiMH in Australia
    The only real advantage of Li-ION is that it's a bit lighter. It has slightly quicker charge/discharge patterns, but in a hybrid environment it makes little effect. And NiMH has better performance in temperature extremes, particularly cold. And heat - can affect longevity.
    The biggest difference I can see is that NiMH has been around for much longer - thus proven in Long Life situations - with Gen2 TAXIs recorded as having run them for up to 800,000 kilometres (or that might have been miles??). There seems to be less degradation with NiMH during the lifetime - but only time will tell, as Gen 4s have only been around for 5 yrs now.
    davecook89t likes this.
  10. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    My 2016 gen4, with NiMh batteries, and 88.529kms (55.009miles), just now:
  11. bisco
    51,883
    nice
    PtPri likes this.
  12. Mendel Leisk
    41,385
    The NIHM are rebuildable, and Lthium not so much, judging by John Kelley’s deep-dive video on a 4th gen battery pack. Believe it was a Prime battery, but same story, just more banks.
