MFD settings
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Feb 12, 2021.
  1. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Hi All,
    My friend has a 05 and I have the 09. Every time he fills up his tank, his average mpg resets to zero automatically. My average miles only change if I hit the reset button and the cruising miles automatically reset. Did different years have slightly different features? Is there a setting to change this?
    Does anyone else's average mpg reset upon fill up?
    #1 ToyotaGal, Feb 12, 2021
    davecook89t likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
  3. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    SFO likes this.
  4. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    So I'm not crazy after all!;) The MPG on our 2007 does not reset when we put gas in the tank, but in a recent thread on this subject, everyone who spoke up said theirs does reset. In fact, the reference I could find in the manual seemed to say that it would reset. I thought our car was unique!
    ToyotaGal likes this.
  5. ToyotaGal
    ToyotaGal Member
    212
    89
    Millis, ma
    Before posting, I looked for a thread and could not find it. Can you post a link to it please? I think there is a hidden preference setting somewhere.
  6. davecook89t
    1,089
    825
    Four Touring
    https://priuschat.com/posts/3115708/
    SFO likes this.
  7. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    I don't know why people can't just answer the question asked. 6 posts and no answer, even the linked thread doesn't answer the question.
    04-05 Prius automatically resets both the milage and the MPG when you fill the tank. This effectively measures the MPG for the tank.
    06-09 Prius only automatically resets the mileage when you fill the tank. If you want to measure tank MPG (as the 04-05 did), you need to press the "Reset" button after you've filled the tank. If you don't it measures average MPG since the "Reset" button was pressed.
    On both, pressing the "Reset" button resets both the milage and the MPG.
    As far as I am aware, there is no secret (or otherwise) setting to change the behavior.
    So, yes, this was a change in the midlife facelift.
    I hope that helps.
    #7 dolj, Feb 13, 2021
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Yep it’s got a little switch on the gas fill door. It’s not magic.
  9. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
  10. dolj
    dolj Senior Member
    8,437
    4,288
    I don't think so. It uses the fuel gauge information to determine 10 L has been added then does the reset if it has. There is no switch on the fuel flap.
