will my 12v battery be alright?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cybervic, Feb 13, 2021.
  1. Cybervic
    Cybervic Junior Member
    East Sussex, UK
    I'd like to get some advice on what to do next please.
    My 12v battery is only 7 month old but I've stupidly left headlight on 4 days and the battery only read 7.9v when I removed it from car. I've now charged it up with 12v battery charger and it now reads 12.10v. Is it safe to put it back to my prius now? Is there a way to test if it'll be alright?
    I used to drive about 30-50 miles per week but I'm in UK and we're in the middle of lockdown so the weekly mileage has been reduced to 5 miles a week.
    #1 Cybervic, Feb 13, 2021
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Yes.
    Is 12v battery still under warranty?
    Cybervic likes this.
  3. Cybervic
    East Sussex, UK
    Yes there is 3 years warranty but T&C says if it's been discharged to below 10.5v then the warranty would be void. Google results seem to suggest that if a battery went below 10v then it's gone. I have health issue and I don't to stuck somewhere if the battery isn't able to hold charges.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    No.
    your killing the hybrid battery too. If I were you I would sell your Prius ASAP while it still has a good hybrid battery because when it fails and it will cause your killing it then it becomes a real hassle to get it repaired or replaced.
    hundreds of posts on here from covid killing the hybrid battery. It is the absolutely wrong car to let sit.
    start reading.
  5. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Cybervic and Mendel Leisk like this.
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Smart play is not to own an aged G2 in this covid times. There still selling very well now. Sell it.
    G2 is only a good car if it has a good hybrid battery and you drive a lot everyday. If you don’t have those 2 it’s a cinder block hanging from your neck.
    Buy a little Kia or Hyundai. No battery.
    If I only drove 5 miles a week I would not own a car in covid I would doubke mask and take a Uber. Save a ton of money.
    then finally Get your 2 shots go buy a car with the money you saved.
    Covid will be a long time till we are all safe. It been 14 months of covid
    My wife tries everyday to get a shot appt after 3 months of trying we got our first text back for her to get a shot next week.
    Probably another few months till we both get a shot.
    Or keep your g2 and drive it at least 5 highway miles everyday watching the battery charging behavior carefully. If you don’t it’s going to get you.....
  7. rjparker
    10,973
    6,882
    The battery is a deep cycle agm from the factory. A direct replacement will also be a deep cycle agm. The rules and warnings for a normal lead acid are not the same for this agm.
    You can be 95% assured it is fine by doing a couple of things. Install and drive it for thirty minutes now. The car will fast charge at much higher amps. Then check the voltage. Hopefully its 12.4v or better. I would then put a four stage low current charger on it (directly in the car) and let it further charge for 8 to 12 hours. Get to the point where it is at least 12.3v after sitting overnight without a charger. Then drive it two or three times a week.
    You can have it load tested at most auto parts suppliers or mechanics. But that test is most accurate when fully charged. Don't be discouraged, many of us have deep discharged an agm and still got 7 years of life out of it. Worse case, you warrantee the battery.
    #7 rjparker, Feb 13, 2021
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Just to clarify, no 12v battery (new or used) in a Prius is going to last very long if you're only driving five (5) miles per week.
    How would they know if it was discharged below 10.5 ?
    On an unpleasant side note; if your catalytic converter hasn't already been nicked, you might consider that possibility as well.
    Cybervic and edthefox5 like this.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Your much better charging it to a full charge now and then. If only to observe it’s charging behavior on the charger. Is it capable of turning the green full charge light on? How long does that take?
    If it can’t that’s the first oh no sign....better start watching it.
    Healthy Prius battery lives at 12.6 volts so I agree with RJ the cars charge voltage is fairly substantial. My yellowtop measures that every time I check it every few months.
    But at lower charging current from a charger it takes forever to get to 13. Something volts.
    My newer Citek mus 4.3 takes about 12 hours to go from 12.6 to 13.3 and turns on its full green light. The fuller it gets the less current it pulls.
    The Citek charges my other car Crown Vic monster lead acid battery much much faster.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. 12.1 is not enough.
    First, charge it longer.
    If it won't go above 12.6 after sitting for a few hours with the charger off, shop for a new one.
    AND if driving only 5 miles a week, you NEED to get a battery tender.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Maybe YOU should start reading.
    Any posts that tend to look that way at first glance, almost always end up being very old vehicles and/or with very high mileage where sitting for a long time unused was just the last straw that finally broke a HV battery that was already on the way out.
    I don't remember seeing even one single post about a long period of un-use "causing" a hybrid battery failure in a relatively new, low mileage vehicle.
    The sky is not falling.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    At which point, it stays at 13.3....which is the float charging voltage and NOT the voltage of the battery itself.
  13. Mendel Leisk
    42,248
    Jut editorial: it’s CTEK.
    edthefox5 and Cybervic like this.
  14. Cybervic
    East Sussex, UK
    Thanks for the inputs. I really love this car and I'd like to continue to own it if possible.
    I'll do a headlight test first. What voltage should I expect to see if the lights turn on OK?
    Can I safely assume that if the engine starts fine then I won't get stuck on a road when I take it out for a charging drive?
  15. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Oops your right. I bough5 because you liked it checked it out it’s pretty nice I like it.
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Well don’t know your technical skills do you own a DVM?
  17. Cybervic
    East Sussex, UK
    I have an DVM, I work in IT so have basic understanding of some technical stuff but not so much with automobile.
  18. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Excellent.
    what does the battery measure at the front jump point with the car off?
  19. Cybervic
    East Sussex, UK
    Battery is currently in the house. The car is parked on street so I had to bring it in to charge it up.
  20. Cybervic
    East Sussex, UK
    I've charged up the battery for 12 hours twice with a break of 8 hours overnight in-between. It reads 12.10v after the 1st charge and still stay the same after 2nd time. A cheap smart 12v 3amp charger was used.
