Toyota iPhone app for 2020 Prius (US owners)
Discussion in 'Gen 4 Prius Audio and Electronics' started by MIkeDr, Oct 15, 2020.
  1. MIkeDr
    MIkeDr Active Member
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    We recently purchased a 2020 Prius AWD-e XLE, and I finally got around to installing and connecting the Toyota iPhone app.
    I was sorta expecting that I would be able to remotely start the car using the app, and do other things like open/close the windows, flash the lights, etc. And be able to retrieve more detailed driving history information (fuel efficiency, etc.).
    But from what I can tell, the only thing the app shows me is the current odometer reading, and a visual gauge of the remaining fuel in the car.
    Is this correct? Or should I be able to see more info/do other things?
  2. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Mine looks like this for my 2021 Prime Ltd. Others have said you were supposed to be able to read oil and tire pressures, but I can’t find it.
  3. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    That's fascinating. Quite useless isn't it?
    kc5dlo and bluespruce like this.
  4. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Tap on the down arrow where it says my garage for tire pressure
  5. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Thanks! I hadn’t realized that. I still don’t understand why I can’t see the amount of gas left as a numeric percentage instead of as a tiny gas gauge.
  6. Leadfoot J. McCoalroller
    8,163
    7,667
    Pennsylvania
    2018 Prius c
    Don't assume that system is aware of it to the level of 1/100 precision. You might be back asking why it always shows the same five numerical values.
  7. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    True. I’d like to see it in 1/8s, which I think is reasonable.
    overall, the app is a bit useless. I was hoping it would report all the eco driving stats that are available in the car itself.
  8. Leadfoot J. McCoalroller
    8,163
    7,667
    Pennsylvania
    2018 Prius c
    That would be cool.
    App integration is lacking in most $25k cars, Prius is nothing special there either.
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    That doesn’t do it on my iPhone app for Prius Prime.
    #9 Db17, Feb 21, 2021
  10. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It does it in my Android app.
  11. Bandy
    Bandy Junior Member
    5th rock
    2022 Prius Prime
    I just got a Prime 2022 a week ago, and the app looks nothing like what is shown here.
    Am I missing something? Or has the PP-app for iphone been downgraded???
    Preparing to blast the dealership...
  12. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Toyota “updated” their app. It looks quite a bit different now.
  13. tomguild
    tomguild smugmobile owner
    28
    Raleigh NC
    2021 Prius
    Actually, most of the useful information goes away after your free one year "connected services" demo expires. I was mildly interested in seeing my car's tire pressure info (not available anywhere in the in-vehicle display. But once my Connected Services plan expired there's essentially nothing of use in the app. And I can't see paying every month just so that fancy "launch missiles" button in the roof can call 911 for me.
    BUT: the app updated at almost the same time as my plan expired (mid-April 2022), and indeed the look and feel of the app is different anyway.
  14. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Hmmm. We’ve had our Prius for 18+ months, and I can still see tire pressure on the app
  15. Bandy
    Bandy Junior Member
    5th rock
    2022 Prius Prime
    I bought my 2022 prime just last month, and set up iphone with the app soon after.
    In the beginning I could see how long the battery would take to charge, and while never accurate at least was a ball park estimate I could work with. App never showed tire pressure, never had the same GUI access as discussed above.
    It never showed a 'My Garage' only a 'Glovebox', and as mentioned, the app is currently just about as useless as it could possibly be.
