List of known hacks / "easter eggs" ?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Brent, Nov 14, 2005.
  1. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    so there is 1 thing better about USA prii...
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Two actually. We did not get heated mirrors on the gen2 even on the top of the range model.
    This makes you wonder who makes these decisions at Toyota when they are fitted in Florida, but not in a country where the climate is prone to be damp, misty, or frosty. This makes the door mirrors more of an ornament than a functioning item. Fortunately this is a very easy add on.
    However I still think we get the better deal with no thermos tank and all that it entails, and the dreaded bladder fuel tank, and all that that entails. This must make the UK versions somewhat lighter than it' US cousins by perhaps 40 to 50lbs. Plus we get rear rotor brakes "discs to us".
    John
  3. 69shovlhed
    2,170
    752
    Delaware
    I wish I could get a non bladder fuel tank. that must be one of the stupidest things Toyota has come up with since the toyopet. even if it meant the check engine light stayed on I would swap the tank anyway.
  4. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    I believe I read through most or all of the posts and didn't see how to open all doors by touching door handle instead of just the drivers door. Anyone have any info on this? Thanks
  5. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    On the fob, press the lock and unlock buttons at the same time and hold for five seconds or so.
    It may be different depending on your year and model.
    Search the forums for unlock all doors, and you will find more info.
    iPad ?
  6. Dovydas
    Dovydas New Member
    DROGHEDA
    Tell me about this?
  7. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
  8. Dovydas
    Dovydas New Member
    DROGHEDA
  9. srellim234
    1,201
    1,694
    Laughlin, Nevada
    There are two other methods listed here
    3 Ways to Disable Reverse Beep in a Toyota Prius - wikiHow
    I don't know if either one of these work with EU models but they might be worth a try if you already have the equipment and apps for other reasons. I don't think I would buy anything hoping it might work for just the reverse beeper.
  10. Abdul Momin
    Abdul Momin New Member
    Pakistan
    Cd recording has been stopped in my prius, Rec button has greyed. I've previously recorded many CD's onto it.
    Would you help me in this regard.
  11. srellim234
    1,201
    1,694
    Laughlin, Nevada
  12. Umerpk
    Umerpk Junior Member
    24
    Pakistan
    Guys any hack for speed limiter? JDM's cruise control is limited to 110km/h and doesn't work beyond that. Any hack to remove this limit? Its a 06 JDM Prius.
  13. ebxgsxr
    ebxgsxr New Member
    Maryland
    stopping the reverse beeping worked great for me on my 2009 Touring. thanks for the info.
  14. Pro-289
    Pro-289 Junior Member
    36
    Stuff 12 easter eggs in the tail pipe. See if the ICE starts. You've been hacked..
