Help: Unidentifiable Button Under Steering Wheel
Discussion in 'Prime Main Forum (2017-2022)' started by WilliamBlake, Feb 24, 2021.
  1. WilliamBlake
    WilliamBlake New Member
    SoCal
    I recently purchased a 2017 Prius Prime, my first hybrid, and I wandered upon this little button below the steering wheel and just above the OBD connector. I admit, I pressed the button several times because that is what buttons are for, to be pressed, but I can't figure out what it does or what its purpose is. Secretly, I was hoping something incredible would happen, but I was let down. I checked the manual and there is nothing about it. There is also a cable that runs from the back of it, so it is powered (I assume) and looks like it might be a light that doesn't work?? Any help is appreciated!
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    I have no idea.
    I own two Priui neither of them has that button.
  3. fotomoto
    fotomoto Senior Member
    5,635
    3,812
    So. Texas
    My guess: vehicle tracker hiding in plain sight.
  4. RovinRon
    RovinRon Junior Member
    33
    22
    Federal Way WA./Sun City AZ.
    That button on our 2017 raised and lowers the steering wheel. Try that and see if that is what it does!
  5. eatriceyo
    eatriceyo Member
    45
    33
    Honolulu
    it looks like one of those overpriced car alarms that dealerships install
    xliderider and Diemaster like this.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  7. Washingtonian
    Washingtonian Senior Member
    726
    621
    Totally different lever to raise and lower the steering wheel. I just checked my Advanced and it doesn't look anything like the OP's pictures.
    I can't see my OBD2 connector and looks like that whole area is a plastic cover for an air bag.
  8. Diemaster
    Diemaster Active Member
    294
    260
    so. cal
    I vote aftermarket dealer installed (probably Karr) alarm. Definitely NOT OEM as it's not on my 2017 prime advanced.
    pghyndman likes this.
  9. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ditto for aftermarket device. I've had three PPs in 3 years and none have the switch.
  10. 3PriusMike
    3,100
    2,419
    Silicon Valley
    A previous model year there was a button to push to reset the low tire pressure set point.
    Another one had a button to disable the smart key (or to put it in a low power mode)
    Mike
  11. M One
    M One Member
    63
    108
    Kuala Lumpur, Malaysia
    Looks like aftermarket gadget. The installer who screwed it in didn't even align it properly
  12. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Agree, it's a dealer or port installed Karr alarm that they try to sell to buyers.
    Yours is probably inactive. Agree as well that they did a shoddy job installing it.
  13. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Definitely not an OEM device. You can call the dealer or seller you bout the car from, but the chances are that unless itis privately sold from the previous owner, they will not have an answer. If you really want to know, I guess, you could open the panel and see where and what component the leads are connected to. But chances are that whatever the aftermarket device it might be, it is not functioning anymore.
  14. WilliamBlake
    SoCal
    Thank you everyone for your help and suggestive ideas about the button. I am going to call the dealership and find out. This was a lease turn in, so I it could have been installed for that driver. I'll post an answer when I find out.
    SeattleBebop1 likes this.
  15. glen whiteman
    glen whiteman New Member
    2022 Prius
    I just purchased a used 2019 Prius XLE and it has the same button on left of steering down low you ever find out what it is thanks.
  16. sylvaing
    sylvaing Senior Member
    1,210
    514
    "WilliamBlake was last seen: Feb 25, 2021”
    I venture you won't hear from him (I think by default this forum doesn't send email regarding replies to your posts) but an image search of his second image brought me to the same conclusion as the others, it's an aftermarket alarm system.
  17. taildragger
    taildragger New Member
    Santa Clara, CA
    I found a similar button on my '21 Prime, just posted a similar inquiry but have not had a reply yet. Will post if I find out.
