2011 Toyota Prius radio randomly turns off.
Discussion in 'Gen 3 Prius Audio and Electronics' started by geegecko, Feb 25, 2021.
  1. geegecko
    geegecko Junior Member
    Charleston, South Carolina
    2011 Toyota Prius radio starting randomly turning off. This the base radio, not the navigation device.
    The LED display turns blank, the preset buttons may work, they may not. Sometimes pressing a preset will turn the unit off. Hitting a pothole in the road may turn the unit off or on.
    The vehicle is well beyond the warranty but I believe I read a number of people having the same issue. I never saw a resolution.
    Thank you for any feedback.
    48,996
    my guess is a loose connection or bad solder joint
  3. AzWxGuy
    AzWxGuy Weather Guy
    970
    491
    Tucson, AZ
    2021 Prius
    Do you have controls for it on the steering wheel? Could be a bad clock spring cable.
