What is in Oil Catch Can! (After 8500 miles)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Mar 20, 2020.
  1. Coots
    Coots Junior Member
    57
    Hailing from parts unknown, Iowa
    I drain mine to the ground at the gas station pump. Zero fks given.
    sometimes I'll drain it into plastic water bottle. usually if it's not cold or wet.
  2. Mendel Leisk
    38,217
    Am I reading that right? Doesn’t sound responsible...
  3. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    :cool::cool::cool::cool:
  4. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    there are so much things out there that people do that’s not responsible, let’s make a list!
  5. Mendel Leisk
    38,217
    Using bald eagle to mop up after changing the oil. (y)
