Tires for 2017 Prius 3 Touring
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Darrell J., Jun 5, 2020.
  1. Coots
    Coots Junior Member
    57
    Hailing from parts unknown, Iowa
    Actually, the 225/45/17 (d=24.97, sidewall height=3.99, change= -0.03%)
    is closer in size to the 195/65/15 than the 205/50/17 (d=25.07, sidewall height=4.04, change=+0.36%). Is the 0.05" sidewall difference noticeable? Probably not.
    The numbers in parenthesis represent change from the 195/65/15.
    The 225 are about half inch wider than the 215, or 0.25" on either side of the tire.
    Basically the trade off is closer to size and slightly wider (the 225), or skinnier and slightly larger (the 205).
  2. David9962000
    David9962000 Member
    139
    66
    2020 Prius
