2019 Prius Prime has no heat
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by 100 free watt hours, Mar 5, 2021.
  1. 100 free watt hours
    100 free watt hours Junior Member
    The heat and a/c quit working in my 2019 prime. The Prime has two heating systems, the regular heater core from the engine coolant and the heat pump (used to be called the air conditioner). When heat pump loses freon from a leak or the compressor goes bad the heating system will only work in defrost mode using the the running engine for heat. The heat pump works quite well and will be assisted by the engine in very cold weather. The heat pump is much more fuel efficient than using a heated coil while running on batteries only. I know this because my heat pump condenser got holes in it from rocks. The condenser sits in front of the radiator exposed to any flying object. Cost to repair is about 1600.00 My insurance will cover most of that because it is road damage. If any one else is experiencing holes in their condenser I would like to know about it. It could be a design flaw in the front grill air intake system.
    48,988
    might be worth installing a radiator guard
  3. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    There was a thread with a video showing how to check refrigerant leaks in the HVAC system of PP after a collision accident. The detail is way beyond my comprehension, but it may be of some use for anyone needing to check the PRIME HVAC system.
    PRIME AC refrigerant O-ring leaks | PriusChat
    I never had a problem with my PP, but aren't most cars have an AC condenser in front of the radiator right behind the grille? My son had a minor frontal collision that did not cause body damages but ended up AC condenser needing to be replaced on my old HCH.
    #3 Salamander_King, Mar 6, 2021
  4. Mendel Leisk
    38,247
    Just for the uninitiated, HCH was your second gen Honda Civic Hybrid.
    I can commiserate: our 06 (also sold to son lol), even without front end damage, started “shedding” it’s condenser grill.
    Continued to keep seal, but pretty pathetic.
    Salamander_King likes this.
  5. vvillovv
    vvillovv Senior Member
    3,536
    1,245
    NY
    I'll commiserate concerning the civic hybrid, even though mine is still on the road, but needs babysitting service since last dealer in warranty service date.
    Just curious if you guys heard about the cali class action - gen 2 civic hybrid didn't get EPA rated 44 mpg combined. around 2012 possibly earlier.
    No big surprise to me it wouldn't get 44 mpg in southern cali...
  6. Mendel Leisk
    38,247
    Towards the end I was happy to get 40... :rolleyes:
  7. vvillovv
    3,536
    1,245
    NY
    I just filled up and mine was 35. No biggy for a 15 year old machine in the cold and snow and only being started once of twice a week when lucky. In the summer I can still get 50's and the best pack still stays balanced for a few months (fingers crossed) if I take it easy. 50 mile return trip a few days ago at 70 mph on the thruway was 46. but that drops fast idling to warm up the pack above freezing.
    I'd sell it if I could and still have a conscience left.
  8. BiomedO1
    1,323
    723
    SacTown, Ca
    Dang conscience!!!:mad::D:LOL::ROFLMAO::sleep: I never saw over 48 mpg, and that was trying really hard in the summer; along the flat valley floors of Cali. Pack went out around 75k; dealer wouldn't replace it unless it threw the battery code a couple of more times. Drove it like I stole, and threw the additional codes. Had to wait another week for the new pack to arrive and got it replaced. Traded it for the Prius C at around 83k and got a really good price; but I had the battery replacement paperwork in hand. I still like Honda's; just not their hybrids.
