Frequent jump starts?
Discussion in 'Prime Main Forum (2017-2022)' started by Kedavis, Mar 30, 2021.
  1. Trollbait
    12,438
    There could also be an aftermarket tracker as possible drain.
    BiomedO1 likes this.
  2. BiomedO1
    3,156
    1,669
    SacTown, Ca
    Yep; saw a thread a few days ago. The sloppy install disable someone's parking brakes - wiring got tangled around the mechanism so the parking brakes won't engage.
  3. Trollbait
    12,438
    Without a sloppy install, the wiring around the OBD plug just need to be checked. These devices plug into that, and have a bypass plug so the OBD can still be used as intended. It will just be a pain looking under the dash for it.
